Date/Time: Sun, 19 Jan 2025 15:11:43 +0000
volume reset when session break?
View Count: 818
[2018-04-18 16:54:42]
Diana - Posts: 42
Does volume reset when session break?
means everyday's 17:00pm break.
If not, how to set?
image360截图20180419004835746.jpg / V - Attached On 2018-04-18 16:50:07 UTC - Size: 90.63 KB - 293 views
[2018-04-18 19:17:23]
Refer to the Volume Per Bar documentation here:
Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Volume Per Bar (Chart >> Chart Settings menu)
You will need to enable New Bar at Session Start:
Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu)
And your Session Times need to be set as needed:
Chart Session Times: Session Times
[2018-04-18 19:20:11]
I assume that you are referring to a new bar at the session start, which in this particular case is a Volume Bar. If this is correct, then as long as you have the option selected for New Bar at Session Start on the Chart >> Chart Settings page (at the bottom center of the image you provided) you will get a new bar at the beginning of what is considered the trading day. For information on this setting refer to the following:
But, this reset is going to occur at the time that you have set for the start of the trading day on this same page (Chart >> Chart Settings), which is currently 00:00 per your Evening Session setting. For information on how to set the Session Times, refer to:
Date Time Of Last Edit: 2018-04-18 19:22:25
