Date/Time: Sun, 19 Jan 2025 15:21:26 +0000
Real time data
View Count: 1139
[2018-04-18 16:18:21] |
User927127 - Posts: 1 |
Hello, regarding servis of real time data for Barchchart - numbers bars I have confirmed with Exchange the agreements base on my knowledge, set in SC to allow supporting data feed. Still cannnot get "M" in the chart. What could be solution from your point of view ? Next step to proceed ? Thank you. Kucera Petr |
[2018-04-18 16:18:31] |
Sierra Chart - Max - Posts: 5779 |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support |
[2018-04-18 17:41:54] |
From user: Hello as requested send you copy of log. AS i have already described i still have problem to not see in numbers bars chart M as confirmation for real time tick data. pls check and let me know. thank you log copy . Reading Internal Order ID file. | 2018-04-18 04:08:11 Reading Trade Orders file. | 2018-04-18 04:08:11 Reading Trade Positions file. | 2018-04-18 04:08:11 Listening on UDP port 22904. | 2018-04-18 04:08:11 Software version: 1727 64-bit | 2018-04-18 04:08:11 Usage end date: 2018-06-21 | 2018-04-18 04:08:11 Enabled for: Advanced Features. | 2018-04-18 04:08:11 Enabled for: Advanced Features 2. | 2018-04-18 04:08:11 Enabled for: Sierra Chart Historical Data Service. | 2018-04-18 04:08:11 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-04-18 04:08:11 Enabled for: INDEXES_DATA_BARCHART | 2018-04-18 04:08:11 Enabled for: CME (Trading Account Required) | 2018-04-18 04:08:11 Enabled for: CBOT (Trading Account Required) | 2018-04-18 04:08:11 Enabled for: COMEX (Trading Account Required) | 2018-04-18 04:08:11 Enabled for: NYMEX (Trading Account Required) | 2018-04-18 04:08:11 Received 1 data feed usernames. | 2018-04-18 04:08:11 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-04-18 04:08:11 Current selected Data/Trading service: Interactive Brokers | 2018-04-18 04:08:11 Chart Update Interval: 500 | 2018-04-18 04:08:11 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-04-18 04:08:11 2018-04-18 04:08:10 Local computer time | 2018-04-18 04:08:11 2018-04-18 09:08:10 Local computer time in UTC | 2018-04-18 04:08:11 2018-04-18 04:08:10 Local computer time in SC Time Zone | 2018-04-18 04:08:11 2018-04-18 09:08:09 Server time in UTC | 2018-04-18 04:08:11 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-04-18 04:08:11 Program path: C:\SierraChart\ | 2018-04-18 04:08:11 Data Files path: C:\SierraChart\Data\ | 2018-04-18 04:08:11 OS Version Number: 6.1 | 2018-04-18 04:08:11 Locale Setting: C | 2018-04-18 04:08:11 Checking for new symbol settings for service code interactive_brokers.trading | 2018-04-18 04:08:11 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-04-18 04:08:11 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-04-18 04:08:11 Requesting symbol settings for service code interactive_brokers.trading. Overwrite = on. | 2018-04-18 04:08:11 Received 5 login tokens. | 2018-04-18 04:08:11 Symbol settings received. | 2018-04-18 04:08:11 Processed 1394 symbol settings. | 2018-04-18 04:08:12 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-04-18 04:08:13 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-04-18 04:08:13 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-04-18 04:08:16 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-04-18 04:08:18 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-04-18 04:08:18 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-04-18 04:08:18 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 04:08:18 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-04-18 04:08:18 Files to Open on Start up | Opening file: NQ.Cht | 2018-04-18 04:08:19 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:08:19 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #1 | Reloading chart. | 2018-04-18 04:08:19 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:08:19 TICK-NYSE-IND-NYSE 2 Min #5 | Reloading chart. | 2018-04-18 04:08:19 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Reloading chart. | 2018-04-18 04:08:20 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Reloading chart. | 2018-04-18 04:08:20 Files to Open on Start up | Opening file: ES1.Cht | 2018-04-18 04:08:20 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:08:21 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #1 | Reloading chart. | 2018-04-18 04:08:22 ES-201806-GLOBEX/ES-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:08:22 $TICk/$TICk 2 Min #5 | Reloading chart. | 2018-04-18 04:08:22 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #4 | Reloading chart. | 2018-04-18 04:08:23 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #6 | Reloading chart. | 2018-04-18 04:08:24 Files to Open on Start up | Opening file: EMD1.Cht | 2018-04-18 04:08:24 EWM18/EWM18 2 Min #2 | Reloading chart. | 2018-04-18 04:08:29 EWM18/EWM18 30 Min #4 | Reloading chart. | 2018-04-18 04:08:30 EWM18/EWM18 2 Min #1 | Reloading chart. | 2018-04-18 04:08:32 EWM18/EWM18 1 Sec #3 | Reloading chart. | 2018-04-18 04:08:34 $TICK 2 Min #5 | Reloading chart. | 2018-04-18 04:08:35 Files to Open on Start up | Opening file: YM.Cht | 2018-04-18 04:08:35 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #2 | Reloading chart. | 2018-04-18 04:08:37 YM-201806-ECBOT/YM-201806-ECBOT 30 Min #4 | Reloading chart. | 2018-04-18 04:08:40 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #1 | Reloading chart. | 2018-04-18 04:08:43 YM-201806-ECBOT/YM-201806-ECBOT 1 Sec #3 | Reloading chart. | 2018-04-18 04:08:44 $TICK 2 Min #5 | Reloading chart. | 2018-04-18 04:08:47 Files to Open on Start up | Opening file: Timeframe 30 min NQ.Cht | 2018-04-18 04:08:48 NQ-201806-GLOBEX/NQ-201806-GLOBEX 30 Min #2 | Reloading chart. | 2018-04-18 04:08:48 NQ-201806-GLOBEX/NQ-201806-GLOBEX #3 | Reloading chart. | 2018-04-18 04:08:55 Files to Open on Start up | Opening file: Timeframe 30 min YM.Cht | 2018-04-18 04:08:55 YM-201806-ECBOT/YM-201806-ECBOT 30 Min #1 | Reloading chart. | 2018-04-18 04:08:57 YM-201806-ECBOT/YM-201806-ECBOT #2 | Reloading chart. | 2018-04-18 04:08:57 Files to Open on Start up | Opening file: Timeframe 30 ES.Cht | 2018-04-18 04:08:57 ES-201806-GLOBEX/ES-201806-GLOBEX 30 Min #1 | Reloading chart. | 2018-04-18 04:09:02 ESM18/ESM18 #2 | Reloading chart. | 2018-04-18 04:09:08 Files to Open on Start up | Opening file: Timeframe 30 min EMD.Cht | 2018-04-18 04:09:11 EWM18/EWM18 30 Min #1 | Reloading chart. | 2018-04-18 04:09:21 EWM18/EWM18 #2 | Reloading chart. | 2018-04-18 04:09:23 TICK-NYSE-IND-NYSE 2 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TICK-NYSE-IND-NYSE.scid | 2018-04-18 04:09:24 Mapping NQ-201806-GLOBEX to NQM18. Service code: cme | 2018-04-18 04:10:15 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 04:10:16 HD Request # 2 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-04-18 04:10:16 HD Request # 2 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:16 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 04:10:16 Socket (6) | Creating socket. | 2018-04-18 04:10:16 Socket (6) | Connecting to IP: 8.18.161.133. | 2018-04-18 04:10:16 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-04-18 04:10:17 HD Request # 2 | Sending historical data logon request message. | 2018-04-18 04:10:17 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-04-18 04:07:42. Record interval: 0. Symbol: NQM18 | 2018-04-18 04:10:17 HD Request # 2 | Decompressing data. | 2018-04-18 04:10:17 Socket (6) | Initiating close of socket by core. | 2018-04-18 04:10:17 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-04-18 04:10:17 Socket (6) | Socket gracefully closed by remote side. | 2018-04-18 04:10:17 Socket (6) | Closed. | 2018-04-18 04:10:17 HD Request # 2 | Historical data for NQ-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-04-18 04:10:17 Historical data download thread signaled to stop. | 2018-04-18 04:10:17 HD Request # 2 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 04:10:17 HD Request # 2 | Completion time: 0s | 2018-04-18 04:10:17 HD Request # 2 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 1 | 2018-04-18 04:10:17 Removed historical data download ID 1 | 2018-04-18 04:10:17 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-04-18 04:10:17 Socket (7) | Creating socket. | 2018-04-18 04:10:17 Socket (7) | Connecting to IP: 127.0.0.1. | 2018-04-18 04:10:17 Interactive Brokers | Sending API sign: API | 2018-04-18 04:10:17 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-04-18 04:10:17 Mapping YM-201806-ECBOT to YMM18. Service code: cbot | 2018-04-18 04:10:18 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 04:10:18 HD Request # 3 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: cbot | 2018-04-18 04:10:18 HD Request # 3 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:18 HD Request # 3 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 04:10:18 Mapping ES-201806-GLOBEX to ESM18. Service code: cme | 2018-04-18 04:10:18 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 04:10:18 Socket (8) | Creating socket. | 2018-04-18 04:10:18 Socket (8) | Connecting to IP: 8.18.161.135. | 2018-04-18 04:10:18 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-04-18 04:10:18 HD Request # 3 | Sending historical data logon request message. | 2018-04-18 04:10:18 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-04-18 04:07:42. Record interval: 0. Symbol: YMM18 | 2018-04-18 04:10:18 HD Request # 3 | Decompressing data. | 2018-04-18 04:10:18 Socket (8) | Initiating close of socket by core. | 2018-04-18 04:10:18 Socket (8) | Shutdown started. Waiting for graceful close. | 2018-04-18 04:10:18 Socket (8) | Socket gracefully closed by remote side. | 2018-04-18 04:10:18 Socket (8) | Closed. | 2018-04-18 04:10:18 HD Request # 3 | Historical data for YM-201806-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-04-18 04:10:19 Historical data download thread signaled to stop. | 2018-04-18 04:10:19 HD Request # 3 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 04:10:19 HD Request # 3 | Completion time: 0s | 2018-04-18 04:10:19 HD Request # 3 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 2 | 2018-04-18 04:10:19 Removed historical data download ID 2 | 2018-04-18 04:10:19 HD Request # 4 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-04-18 04:10:19 HD Request # 4 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:19 HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 04:10:19 Socket (9) | Creating socket. | 2018-04-18 04:10:19 Socket (9) | Connecting to IP: 8.18.161.133. | 2018-04-18 04:10:19 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-04-18 04:10:19 HD Request # 4 | Sending historical data logon request message. | 2018-04-18 04:10:19 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-04-18 04:07:42. Record interval: 0. Symbol: ESM18 | 2018-04-18 04:10:19 HD Request # 4 | Decompressing data. | 2018-04-18 04:10:19 Socket (9) | Initiating close of socket by core. | 2018-04-18 04:10:19 Socket (9) | Shutdown started. Waiting for graceful close. | 2018-04-18 04:10:19 Socket (9) | Socket gracefully closed by remote side. | 2018-04-18 04:10:19 Socket (9) | Closed. | 2018-04-18 04:10:19 HD Request # 4 | Historical data for ES-201806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-04-18 04:10:19 Historical data download thread signaled to stop. | 2018-04-18 04:10:19 HD Request # 4 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 04:10:19 HD Request # 4 | Completion time: 1s | 2018-04-18 04:10:19 HD Request # 4 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 3 | 2018-04-18 04:10:19 Removed historical data download ID 3 | 2018-04-18 04:10:19 Interactive Brokers | TWS server version: 136 | 2018-04-18 04:10:20 Interactive Brokers | TWS time: 20180418 04:10:18 CST | 2018-04-18 04:10:20 Interactive Brokers | Connected. Sending Start API command. | 2018-04-18 04:10:20 Interactive Brokers | Waiting for account information. | 2018-04-18 04:10:20 IB Account information received. | 2018-04-18 04:10:21 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-04-18 04:10:21 Interactive Brokers | Connected to Demo or Simulated account. | 2018-04-18 04:10:21 Interactive Brokers | Not previously connected to Live account. | 2018-04-18 04:10:21 Interactive Brokers | Connected to data and trading server. | 2018-04-18 04:10:21 Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-04-18 04:10:21 Next valid order ID: 1 | 2018-04-18 04:10:21 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:10:21 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:10:21 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:10:21 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:10:21 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:10:21 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:10:21 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:10:21 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:10:21 Interactive Brokers | Starting real-time market data updates for: NQ-201806-GLOBEX. ID: 1 | 2018-04-18 04:10:21 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 04:10:21 Interactive Brokers | Requesting security definition data for: NQ-201806-GLOBEX. ID: 1 | 2018-04-18 04:10:21 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-04-18 04:10:21 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 04:10:21 Next valid order ID: 1 | 2018-04-18 04:10:21 Delaying start of download for NQ-201806-GLOBEX | 2018-04-18 04:10:21 Interactive Brokers | Starting real-time market data updates for: TICK-NYSE-IND-NYSE. ID: 2 | 2018-04-18 04:10:21 Interactive Brokers | Subscribing to Symbol: (Using local symbol), SecurityType: IND, Expiration: , Exchange: NYSE, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: TICK-NYSE, TradingClass: | 2018-04-18 04:10:21 Interactive Brokers | Requesting security definition data for: TICK-NYSE-IND-NYSE. ID: 2 | 2018-04-18 04:10:21 Interactive Brokers | Using primary service for historical data for TICK-NYSE-IND-NYSE | 2018-04-18 04:10:21 Intraday data recording state for symbol TICK-NYSE-IND-NYSE is set to download 'Pending'. | 2018-04-18 04:10:21 Delaying start of download for TICK-NYSE-IND-NYSE | 2018-04-18 04:10:21 Interactive Brokers | Starting real-time market data updates for: YM-201806-ECBOT. ID: 3 | 2018-04-18 04:10:21 Interactive Brokers | Subscribing to Symbol: YM, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 04:10:21 Interactive Brokers | Requesting security definition data for: YM-201806-ECBOT. ID: 3 | 2018-04-18 04:10:21 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YM-201806-ECBOT | 2018-04-18 04:10:21 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 04:10:21 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 04:10:21 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 04:10:21 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 04:10:21 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-04-18 04:10:21 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 04:10:21 Interactive Brokers | Starting real-time market data updates for: $TICk. ID: 5 | 2018-04-18 04:10:21 Interactive Brokers | Subscribing to Symbol: $TICk, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 04:10:21 Interactive Brokers | Requesting security definition data for: $TICk. ID: 5 | 2018-04-18 04:10:21 Interactive Brokers | Using primary service for historical data for $TICk | 2018-04-18 04:10:21 Intraday data recording state for symbol $TICk is set to download 'Pending'. | 2018-04-18 04:10:21 Interactive Brokers | Starting real-time market data updates for: EWM18. ID: 6 | 2018-04-18 04:10:21 Interactive Brokers | Subscribing to Symbol: EWM18, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 04:10:21 Interactive Brokers | Requesting security definition data for: EWM18. ID: 6 | 2018-04-18 04:10:21 Interactive Brokers | Using primary service for historical data for EWM18 | 2018-04-18 04:10:21 Intraday data recording state for symbol EWM18 is set to download 'Pending'. | 2018-04-18 04:10:21 Interactive Brokers | Starting real-time market data updates for: ESM18. ID: 7 | 2018-04-18 04:10:22 Interactive Brokers | Subscribing to Symbol: ESM18, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 04:10:22 Interactive Brokers | Requesting security definition data for: ESM18. ID: 7 | 2018-04-18 04:10:22 Interactive Brokers | Using primary service for historical data for ESM18 | 2018-04-18 04:10:22 Intraday data recording state for symbol ESM18 is set to download 'Pending'. | 2018-04-18 04:10:22 Interactive Brokers | Market data type is Delayed for NQ-201806-GLOBEX | 2018-04-18 04:10:26 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 1. Symbol: NQ-201806-GLOBEX. | 2018-04-18 04:10:26 Message from IB: Requested market data is not subscribed.Delayed market data is not available.TICK-NYSE NYSE TICK INDEX/TOP/ALL. IB Error Code: 354. Request ID: 2. Symbol: TICK-NYSE-IND-NYSE. | 2018-04-18 04:10:26 Interactive Brokers | Market data type is Delayed for YM-201806-ECBOT | 2018-04-18 04:10:26 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 3. Symbol: YM-201806-ECBOT. | 2018-04-18 04:10:26 Interactive Brokers | Market data type is Delayed for ES-201806-GLOBEX | 2018-04-18 04:10:27 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 4. Symbol: ES-201806-GLOBEX. | 2018-04-18 04:10:27 Symbol Error - $TICk is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:10:27 Symbol Error - $TICk is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:10:27 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:10:27 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:10:27 Symbol Error - ESM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:10:27 Symbol Error - ESM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:10:27 Requesting market depth updates for: ES-201806-GLOBEX if supported. | 2018-04-18 04:10:27 Requesting market depth updates for: EWM18 if supported. | 2018-04-18 04:10:27 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 04:10:27 Requesting market depth updates for: YM-201806-ECBOT if supported. | 2018-04-18 04:10:27 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: DU10* | 2018-04-18 04:10:27 Delaying start of download for NQ-201806-GLOBEX | 2018-04-18 04:10:27 Symbol Error - (unknown symbol with ID 100006) is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:10:27 Interactive Brokers | Received Trade Positions download end message for account DU10* | 2018-04-18 04:10:28 Message from IB: Requested market data is not subscribed.Delayed market data is not available.ES JUN'18/DEEP. IB Error Code: 354. Request ID: 100004. | 2018-04-18 04:10:28 Message from IB: Requested market data is not subscribed.Delayed market data is not available.NQ JUN'18/DEEP. IB Error Code: 354. Request ID: 100001. | 2018-04-18 04:10:28 Message from IB: Requested market data is not subscribed.Delayed market data is not available.YM JUN'18/DEEP. IB Error Code: 354. Request ID: 100003. | 2018-04-18 04:10:28 HD Request # 5 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-04-18 04:10:32 HD Request # 5 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:32 HD Request # 5 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 04:10:32 Socket (11) | Creating socket. | 2018-04-18 04:10:32 Socket (11) | Connecting to IP: 8.18.161.135. | 2018-04-18 04:10:32 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-04-18 04:10:32 HD Request # 5 | Sending historical data logon request message. | 2018-04-18 04:10:32 HD Request # 5 | Requesting Intraday data. Start date-time: 2018-04-18 04:07:42. Record interval: 0. Symbol: NQM18 | 2018-04-18 04:10:32 HD Request # 5 | Decompressing data. | 2018-04-18 04:10:32 Socket (11) | Initiating close of socket by core. | 2018-04-18 04:10:32 Socket (11) | Shutdown started. Waiting for graceful close. | 2018-04-18 04:10:32 Socket (11) | Socket gracefully closed by remote side. | 2018-04-18 04:10:32 Socket (11) | Closed. | 2018-04-18 04:10:32 Historical data download thread signaled to stop. | 2018-04-18 04:10:32 HD Request # 5 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 04:10:32 HD Request # 5 | Completion time: 1s | 2018-04-18 04:10:32 HD Request # 5 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 4 | 2018-04-18 04:10:32 Removed historical data download ID 4 | 2018-04-18 04:10:32 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 04:10:32 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 04:10:32 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-04-18 04:10:32 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 04:10:32 HD Request # 6 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: cbot | 2018-04-18 04:10:32 HD Request # 6 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:32 HD Request # 6 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 04:10:32 Socket (12) | Creating socket. | 2018-04-18 04:10:32 Socket (12) | Connecting to IP: 8.18.161.133. | 2018-04-18 04:10:32 HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-04-18 04:10:32 HD Request # 6 | Sending historical data logon request message. | 2018-04-18 04:10:32 HD Request # 6 | Requesting Intraday data. Start date-time: 2018-04-18 04:07:42. Record interval: 0. Symbol: YMM18 | 2018-04-18 04:10:32 HD Request # 6 | Decompressing data. | 2018-04-18 04:10:32 Socket (12) | Initiating close of socket by core. | 2018-04-18 04:10:32 Socket (12) | Shutdown started. Waiting for graceful close. | 2018-04-18 04:10:32 Socket (12) | Socket gracefully closed by remote side. | 2018-04-18 04:10:32 Socket (12) | Closed. | 2018-04-18 04:10:32 Historical data download thread signaled to stop. | 2018-04-18 04:10:33 HD Request # 6 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 04:10:33 HD Request # 6 | Completion time: 0s | 2018-04-18 04:10:33 HD Request # 6 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 6 | 2018-04-18 04:10:33 Removed historical data download ID 6 | 2018-04-18 04:10:33 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 04:10:33 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 04:10:33 Interactive Brokers | Using primary service for historical data for YM-201806-ECBOT | 2018-04-18 04:10:33 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 04:10:33 HD Request # 7 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-04-18 04:10:33 HD Request # 7 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:33 HD Request # 7 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 04:10:33 Socket (13) | Creating socket. | 2018-04-18 04:10:33 Socket (13) | Connecting to IP: 8.18.161.135. | 2018-04-18 04:10:33 HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-04-18 04:10:33 HD Request # 7 | Sending historical data logon request message. | 2018-04-18 04:10:33 HD Request # 7 | Requesting Intraday data. Start date-time: 2018-04-18 04:07:42. Record interval: 0. Symbol: ESM18 | 2018-04-18 04:10:33 HD Request # 7 | Decompressing data. | 2018-04-18 04:10:33 Socket (13) | Initiating close of socket by core. | 2018-04-18 04:10:33 Historical data download thread signaled to stop. | 2018-04-18 04:10:33 Socket (13) | Shutdown started. Waiting for graceful close. | 2018-04-18 04:10:33 HD Request # 7 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 04:10:33 HD Request # 7 | Completion time: 0s | 2018-04-18 04:10:33 HD Request # 7 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 7 | 2018-04-18 04:10:33 Removed historical data download ID 7 | 2018-04-18 04:10:33 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 04:10:33 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 04:10:33 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-04-18 04:10:33 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 04:10:33 Socket (13) | Socket gracefully closed by remote side. | 2018-04-18 04:10:33 Socket (13) | Closed. | 2018-04-18 04:10:33 HD Request # 8 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: interactive_brokers.trading | 2018-04-18 04:10:35 HD Request # 8 | Download start date-time: 2017-10-14 04:10:34.000 | 2018-04-18 04:10:35 HD Request # 8 | Requesting a total of 21 days and 0 seconds. | 2018-04-18 04:10:35 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2018-04-18 04:10:35 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-29 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:35 HD Request # 8 | Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200002. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1641600. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-30 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200003. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1555200. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-31 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200003. | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200004. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1468800. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-01 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200004. | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200005. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1382400. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-02 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200006. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1296000. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-03 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200005. | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200007. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1209600. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-04 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200006. | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200008. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1123200. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-05 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200007. | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200009. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1036800. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-06 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200008. | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200009. | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200010. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 950400. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-07 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200010. | 2018-04-18 04:10:36 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200011. | 2018-04-18 04:10:36 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 864000. | 2018-04-18 04:10:36 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-08 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:36 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200011. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200012. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 777600. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-09 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 * Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200012. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200013. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 691200. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-10 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200013. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200014. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 604800. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-11 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200014. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200015. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 518400. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-12 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200015. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200016. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 432000. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-13 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200016. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200017. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 345600. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-14 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200017. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200018. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 259200. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-15 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200018. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200019. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 172800. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-16 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200019. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200020. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 86400. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-17 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200020. | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200021. | 2018-04-18 04:10:37 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 0. | 2018-04-18 04:10:37 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-18 05:20:34 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 04:10:37 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200022. | 2018-04-18 04:10:37 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 04:10:37 HD Request # 8 | Completion time: 3s | 2018-04-18 04:10:37 HD Request # 8 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 5 | 2018-04-18 04:10:37 Removed historical data download ID 5 | 2018-04-18 04:10:37 Real-time Intraday chart data file updates started for TICK-NYSE-IND-NYSE | 2018-04-18 04:10:37 Intraday chart data file opened for TICK-NYSE-IND-NYSE | 2018-04-18 04:10:37 HD Request # 9 | Downloading Intraday chart data for $TICk to the file $TICk.scid. Service: interactive_brokers.trading | 2018-04-18 04:10:37 HD Request # 9 | Download start date-time: 2018-04-16 15:04:00.000 | 2018-04-18 04:10:37 HD Request # 9 | Requesting a total of 1 days and 51997 seconds. | 2018-04-18 04:10:37 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 51997. | 2018-04-18 04:10:37 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-17 14:54:00 for $TICk. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200021. | 2018-04-18 04:10:37 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200022. | 2018-04-18 04:10:37 HD Request # 9 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200023. | 2018-04-18 04:10:37 HD Request # 9 | Error downloading historical Intraday data for $TICk. The symbol is unknown to the server. | 2018-04-18 04:10:37 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TICk | 2018-04-18 04:10:37 HD Request # 9 | Completion time: 0s | 2018-04-18 04:10:37 HD Request # 9 | Intraday data download complete for $TICk. Unique request ID: 8 | 2018-04-18 04:10:37 Removed historical data download ID 8 | 2018-04-18 04:10:37 Real-time Intraday chart data file updates started for $TICk | 2018-04-18 04:10:37 Intraday chart data file opened for $TICk | 2018-04-18 04:10:37 HD Request # 10 | Downloading Intraday chart data for EWM18 to the file EWM18.scid. Service: interactive_brokers.trading | 2018-04-18 04:10:37 HD Request # 10 | Download start date-time: 2018-04-17 02:25:36.000 | 2018-04-18 04:10:37 HD Request # 10 | Requesting a total of 1 days and 11101 seconds. | 2018-04-18 04:10:37 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 11101. | 2018-04-18 04:10:37 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-18 02:15:36 for EWM18. PriceType: TRADES | 2018-04-18 04:10:37 Message from IB: No historical data query found for ticker id:200023. IB Error Code: 366. Request ID: 200023. | 2018-04-18 04:10:38 HD Request # 10 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200024. | 2018-04-18 04:10:38 HD Request # 10 | Error downloading historical Intraday data for EWM18. The symbol is unknown to the server. | 2018-04-18 04:10:38 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EWM18 | 2018-04-18 04:10:38 HD Request # 10 | Completion time: 0s | 2018-04-18 04:10:38 HD Request # 10 | Intraday data download complete for EWM18. Unique request ID: 9 | 2018-04-18 04:10:38 Removed historical data download ID 9 | 2018-04-18 04:10:38 Real-time Intraday chart data file updates started for EWM18 | 2018-04-18 04:10:38 Intraday chart data file opened for EWM18 | 2018-04-18 04:10:38 Message from IB: No historical data query found for ticker id:200024. IB Error Code: 366. Request ID: 200024. | 2018-04-18 04:10:38 HD Request # 11 | Downloading Intraday chart data for ESM18 to the file ESM18.scid. Service: interactive_brokers.trading | 2018-04-18 04:10:38 HD Request # 11 | Download start date-time: 2018-04-17 02:27:37.000 | 2018-04-18 04:10:38 HD Request # 11 | Requesting a total of 1 days and 10980 seconds. | 2018-04-18 04:10:38 HD Request # 11 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 10980. | 2018-04-18 04:10:38 HD Request # 11 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-18 02:17:37 for ESM18. PriceType: TRADES | 2018-04-18 04:10:38 HD Request # 11 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200025. | 2018-04-18 04:10:38 HD Request # 11 | Error downloading historical Intraday data for ESM18. The symbol is unknown to the server. | 2018-04-18 04:10:38 HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM18 | 2018-04-18 04:10:38 HD Request # 11 | Completion time: 0s | 2018-04-18 04:10:38 HD Request # 11 | Intraday data download complete for ESM18. Unique request ID: 10 | 2018-04-18 04:10:38 Removed historical data download ID 10 | 2018-04-18 04:10:38 Real-time Intraday chart data file updates started for ESM18 | 2018-04-18 04:10:38 Intraday chart data file opened for ESM18 | 2018-04-18 04:10:38 Message from IB: No historical data query found for ticker id:200025. IB Error Code: 366. Request ID: 200025. | 2018-04-18 04:10:38 HD Request # 12 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 04:10:38 HD Request # 12 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:38 HD Request # 12 | Requesting a total of 0 days and 4975 seconds. | 2018-04-18 04:10:38 HD Request # 12 | IB Backfill - Seconds requested: 4975. Seconds Remaining: 0. | 2018-04-18 04:10:38 HD Request # 12 | Requesting 4975 Seconds of data at 30 secs with ending date-time at 2018-04-18 05:20:37 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-04-18 04:10:38 HD Request # 12 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200026. | 2018-04-18 04:10:38 HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 04:10:38 HD Request # 12 | Completion time: 1s | 2018-04-18 04:10:38 HD Request # 12 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 11 | 2018-04-18 04:10:38 Removed historical data download ID 11 | 2018-04-18 04:10:38 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 04:10:38 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 04:10:38 HD Request # 13 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-04-18 04:10:38 HD Request # 13 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:38 HD Request # 13 | Requesting a total of 0 days and 4976 seconds. | 2018-04-18 04:10:38 HD Request # 13 | IB Backfill - Seconds requested: 4976. Seconds Remaining: 0. | 2018-04-18 04:10:38 HD Request # 13 | Requesting 4976 Seconds of data at 30 secs with ending date-time at 2018-04-18 05:20:38 for YM-201806-ECBOT. PriceType: TRADES | 2018-04-18 04:10:38 HD Request # 13 | Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 200027. | 2018-04-18 04:10:38 HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 04:10:38 HD Request # 13 | Completion time: 0s | 2018-04-18 04:10:38 HD Request # 13 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 12 | 2018-04-18 04:10:38 Removed historical data download ID 12 | 2018-04-18 04:10:38 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 04:10:38 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 04:10:38 HD Request # 14 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 04:10:38 HD Request # 14 | Download start date-time: 2018-04-18 04:07:42.000 | 2018-04-18 04:10:38 HD Request # 14 | Requesting a total of 0 days and 4976 seconds. | 2018-04-18 04:10:38 HD Request # 14 | IB Backfill - Seconds requested: 4976. Seconds Remaining: 0. | 2018-04-18 04:10:38 HD Request # 14 | Requesting 4976 Seconds of data at 30 secs with ending date-time at 2018-04-18 05:20:38 for ES-201806-GLOBEX. PriceType: TRADES | 2018-04-18 04:10:38 HD Request # 14 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200028. | 2018-04-18 04:10:38 HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 04:10:38 HD Request # 14 | Completion time: 0s | 2018-04-18 04:10:38 HD Request # 14 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 13 | 2018-04-18 04:10:38 Removed historical data download ID 13 | 2018-04-18 04:10:38 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 04:10:38 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 04:10:38 Opened cached Intraday file: C:\SierraChart\Data\YM-201806-ECBOT.scid | 2018-04-18 04:10:44 Opened cached Intraday file: C:\SierraChart\Data\NQ-201806-GLOBEX.scid | 2018-04-18 04:10:47 Opened cached Intraday file: C:\SierraChart\Data\ES-201806-GLOBEX.scid | 2018-04-18 04:10:56 NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 04:12:27 Interactive Brokers | Starting real-time market data updates for: NQM18. ID: 8 | 2018-04-18 04:12:28 Interactive Brokers | Subscribing to Symbol: NQM18, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 04:12:28 Interactive Brokers | Requesting security definition data for: NQM18. ID: 8 | 2018-04-18 04:12:28 Interactive Brokers | Using primary service for historical data for NQM18 | 2018-04-18 04:12:28 Intraday data recording state for symbol NQM18 is set to download 'Pending'. | 2018-04-18 04:12:28 Delaying start of download for NQM18 | 2018-04-18 04:12:28 Symbol Error - NQM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:12:28 Symbol Error - NQM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:12:28 HD Request # 15 | Downloading Intraday chart data for NQM18 to the file NQM18.scid. Service: interactive_brokers.trading | 2018-04-18 04:12:29 HD Request # 15 | Download start date-time: 2018-04-17 02:27:40.000 | 2018-04-18 04:12:29 HD Request # 15 | Requesting a total of 1 days and 11089 seconds. | 2018-04-18 04:12:29 HD Request # 15 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 11089. | 2018-04-18 04:12:29 HD Request # 15 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-18 02:17:40 for NQM18. PriceType: TRADES | 2018-04-18 04:12:29 HD Request # 15 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200029. | 2018-04-18 04:12:29 HD Request # 15 | Error downloading historical Intraday data for NQM18. The symbol is unknown to the server. | 2018-04-18 04:12:29 HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQM18 | 2018-04-18 04:12:29 HD Request # 15 | Completion time: 0s | 2018-04-18 04:12:30 HD Request # 15 | Intraday data download complete for NQM18. Unique request ID: 14 | 2018-04-18 04:12:30 Removed historical data download ID 14 | 2018-04-18 04:12:30 Real-time Intraday chart data file updates started for NQM18 | 2018-04-18 04:12:30 Intraday chart data file opened for NQM18 | 2018-04-18 04:12:30 Message from IB: No historical data query found for ticker id:200029. IB Error Code: 366. Request ID: 200029. | 2018-04-18 04:12:30 Unsubscribed from market depth data for NQ-201806-GLOBEX | 2018-04-18 04:12:32 Requesting market depth updates for: NQM18 if supported. | 2018-04-18 04:12:32 Message from IB: Can't find the subscribed market depth with tickerId:100001. IB Error Code: 310. Request ID: 100001. | 2018-04-18 04:12:32 Symbol Error - (unknown symbol with ID 100008) is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 04:12:32 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:14:36 Message from IB: HMDS data farm connection is broken:ilhmds. IB Error Code: 2105. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is broken:usfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is broken:usfarm.us. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: HMDS data farm connection is broken:ushmds. IB Error Code: 2105. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: HMDS data farm connection is broken:ushmds.us. IB Error Code: 2105. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is broken:secdefil. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is OK:secdefil. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:14:37 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:14:56 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:15:03 Replay 5.00X: NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 04:15:03 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:15:03 + Loading market depth data. | 2018-04-18 04:15:05 Replay 5.00X: NQM18/nqm18 2 Min #1 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:15:05 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:15:24 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:15:24 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:15:24 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:15:24 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:15:27 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:15:27 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:15:30 Replay 5.00X: NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 04:15:30 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:15:30 Replay 5.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Reloading chart. | 2018-04-18 04:15:31 Replay 5.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Reloading chart. | 2018-04-18 04:15:31 + Loading market depth data. | 2018-04-18 04:15:31 Replay 5.00X: NQM18/nqm18 2 Min #1 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:15:33 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:17:40 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:17:40 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:17:40 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:17:40 Replay 5.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:17:40 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Reloading chart. | 2018-04-18 04:17:40 Replay 5.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:17:40 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Reloading chart. | 2018-04-18 04:17:40 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:17:54 Replay 5.00X: NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 04:17:54 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:17:54 Replay 5.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Reloading chart. | 2018-04-18 04:17:56 Replay 5.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Reloading chart. | 2018-04-18 04:17:56 + Loading market depth data. | 2018-04-18 04:18:01 Replay 5.00X: NQM18/nqm18 2 Min #1 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:18:01 NQM18/nqm18 2 Min #1 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:01 NQM18/nqm18 2 Min #1 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:02 Replay 5.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:04 Replay 5.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:04 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:06 Replay 5.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:06 NQM18/nqm18 2 Min #1 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:06 Replay 5.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:08 Replay 5.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:18:08 Replay 5.00X: NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 04:18:56 + Loading market depth data. | 2018-04-18 04:18:56 Replay 1.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:19:17 Replay 1.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:19:17 Replay 1.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:19:17 Replay 1.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:19:17 Replay 1.00X: NQM18/nqm18 2 Min #1 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:19:17 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:38 Message from IB: HMDS data farm connection is broken:ilhmds. IB Error Code: 2105. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:secdefil. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: HMDS data farm connection is broken:ushmds. IB Error Code: 2105. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:usfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:usfarm.us. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: HMDS data farm connection is broken:ushmds.us. IB Error Code: 2105. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is broken:usfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:19:39 Message from IB: Market data farm connection is OK:secdefil. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:19:40 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:19:40 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:19:40 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 04:19:40 Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:20:02 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:20:04 Message from IB: Market data farm connection is broken:usfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:20:04 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:20:05 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:20 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:20 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:20 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:20 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:20:21 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:20:22 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:20:22 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:20:22 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:25 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:25 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:26 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:27 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:27 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:27 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:27 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:29 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:29 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:29 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:29 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:34 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:34 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:34 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:34 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:36 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:36 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:37 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:37 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:37 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:38 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:44 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:44 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:44 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:45 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:48 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:48 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:48 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:49 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:49 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:49 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:20:49 Message from IB: Market data farm connection is broken:cashfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:20:50 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:20:50 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:20:51 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:20:51 Replay 1.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:21:47 Replay 1.00X: NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 04:21:47 Replay 1.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:21:48 Replay 1.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Reloading chart. | 2018-04-18 04:21:48 Replay 1.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Reloading chart. | 2018-04-18 04:21:48 + Loading market depth data. | 2018-04-18 04:21:48 Message from IB: Market data farm connection is broken:usfarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:24:07 Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:24:07 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:24:07 Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:24:07 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:24:07 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:24:08 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:24:12 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:24:13 Message from IB: Market data farm connection is broken:eufarm. IB Error Code: 2103. Request ID: -1. | 2018-04-18 04:24:43 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 04:24:43 Replay 1.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:28:28 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 04:28:28 Replay 1.00X: NQM18/nqm18 2 Min #1 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:28:28 NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 04:28:28 Replay 1.00X: NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:28:28 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | Reloading chart. | 2018-04-18 04:28:29 Replay 1.00X: YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:28:29 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | Reloading chart. | 2018-04-18 04:28:30 Replay 1.00X: ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 0 | 2018-04-18 04:28:30 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | Reloading chart. | 2018-04-18 04:28:31 NQM18/nqm18 1 Min #1 | Reloading chart. | 2018-04-18 04:28:56 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | Reloading chart. | 2018-04-18 04:30:13 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:30:27 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:30:32 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:30:32 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:30:33 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:24 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:25 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:25 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:25 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:26 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:27 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:27 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:27 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:28 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:34 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:35 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:35 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:35 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:35 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:39 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:39 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:39 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:44 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:44 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:44 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:44 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:47 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:48 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:48 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:49 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:49 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:49 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:49 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:52 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:53 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:54 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:54 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:54 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:54 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:56 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:56 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:57 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:59 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:59 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:31:59 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:02 ES-201806-GLOBEX/ES-201806-GLOBEX 2 Min #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:02 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:02 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:04 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:04 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:04 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:06 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:06 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Min #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:06 YM-201806-ECBOT/YM-201806-ECBOT 2 Min #4 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:08 NQ-201806-GLOBEX/NQ-201806-GLOBEX 1 Sec #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2018-04-18 04:32:08 NQM18/nqm18 2 Min #1 | Reloading chart. | 2018-04-18 05:52:50 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #2 | Reloading chart. | 2018-04-18 05:54:14 Interactive Brokers | Stopping automatic Trade Position updates for account: DU10* | 2018-04-18 08:08:56 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: DU10* | 2018-04-18 08:08:56 Message from IB: API client has been unsubscribed from account data. IB Error Code: 2100. Request ID: -1. | 2018-04-18 08:08:56 Interactive Brokers | Received Trade Positions download end message for account DU10* | 2018-04-18 08:08:56 NQ-201806-GLOBEX/NQ-201806-GLOBEX 2 Min #1 | Reloading chart. | 2018-04-18 09:21:08 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 09:21:12 Message from IB: Requested market data is not subscribed.Delayed market data is not available.NQ JUN'18/DEEP. IB Error Code: 354. Request ID: 100001. | 2018-04-18 09:21:13 ES-201806-GLOBEX/ES-201806-GLOBEX #2 | Reloading chart. | 2018-04-18 09:29:38 File >> Disconnect selected. | 2018-04-18 09:40:40 Socket (7) | 336 bytes remaining in receive buffer when socket closed. | 2018-04-18 09:40:46 Socket (7) | Initiating close of socket by core. | 2018-04-18 09:40:46 Socket (7) | Shutdown started. Waiting for graceful close. | 2018-04-18 09:40:46 Interactive Brokers | Disconnected. | 2018-04-18 09:40:46 Socket (7) | Socket gracefully closed by remote side. | 2018-04-18 09:40:46 Socket (7) | Closed. | 2018-04-18 09:40:46 Checking for new symbol settings for service code scdataallservices | 2018-04-18 09:41:11 HTTPS connection to www.sierrachart.com:443 (346) | Creating socket. Using TLS 1.2. | 2018-04-18 09:41:11 HTTPS connection to www.sierrachart.com:443 (346) | Connecting to IP: 204.15.192.108. | 2018-04-18 09:41:11 Current selected Data/Trading service: SC Data - All Services | 2018-04-18 09:41:11 Requesting symbol settings for service code scdataallservices. Overwrite = on. | 2018-04-18 09:41:16 SC Data - All Services | Connected to data server. | 2018-04-18 09:41:17 Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-04-18 09:41:17 SC Data - All Services | Starting real-time market data updates for: EWM18. ID: 1 | 2018-04-18 09:41:17 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: EWM18 | 2018-04-18 09:41:17 SC Data - All Services | Requesting security definition data for: EWM18. ID: 1 | 2018-04-18 09:41:17 Intraday data recording state for symbol EWM18 is set to download 'Pending'. | 2018-04-18 09:41:17 Delaying start of download for EWM18 | 2018-04-18 09:41:17 SC Data - All Services | Starting real-time market data updates for: YM-201806-ECBOT. ID: 2 | 2018-04-18 09:41:17 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: YM-201806-ECBOT | 2018-04-18 09:41:17 SC Data - All Services | Requesting security definition data for: YM-201806-ECBOT. ID: 2 | 2018-04-18 09:41:17 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 09:41:17 Delaying start of download for YM-201806-ECBOT | 2018-04-18 09:41:17 SC Data - All Services | Starting real-time market data updates for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 09:41:17 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQ-201806-GLOBEX | 2018-04-18 09:41:17 SC Data - All Services | Requesting security definition data for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 09:41:17 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 09:41:17 SC Data - All Services | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 09:41:17 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ES-201806-GLOBEX | 2018-04-18 09:41:17 SC Data - All Services | Requesting security definition data for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 09:41:17 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 09:41:17 SC Data - All Services | Starting real-time market data updates for: TICK-NYSE-IND-NYSE. ID: 5 | 2018-04-18 09:41:17 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: TICK-NYSE-IND-NYSE | 2018-04-18 09:41:17 SC Data - All Services | Requesting security definition data for: TICK-NYSE-IND-NYSE. ID: 5 | 2018-04-18 09:41:17 Intraday data recording state for symbol TICK-NYSE-IND-NYSE is set to download 'Pending'. | 2018-04-18 09:41:17 SC Data - All Services | Starting real-time market data updates for: $TICk. ID: 6 | 2018-04-18 09:41:17 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: $TICk | 2018-04-18 09:41:17 SC Data - All Services | Requesting security definition data for: $TICk. ID: 6 | 2018-04-18 09:41:17 Intraday data recording state for symbol $TICk is set to download 'Pending'. | 2018-04-18 09:41:17 Delaying start of download for EWM18 | 2018-04-18 09:41:18 Delaying start of download for YM-201806-ECBOT | 2018-04-18 09:41:18 Symbol settings received. | 2018-04-18 09:41:20 Processed 5574 symbol settings. | 2018-04-18 09:41:24 It is recommended to reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed' | 2018-04-18 09:41:24 Requesting market depth updates for: ES-201806-GLOBEX if supported. | 2018-04-18 09:41:24 Requesting market depth updates for: EWM18 if supported. | 2018-04-18 09:41:24 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 09:41:24 Requesting market depth updates for: YM-201806-ECBOT if supported. | 2018-04-18 09:41:24 HD Request # 16 | Downloading Intraday chart data for EWM18 to the file EWM18.scid. Service: cme | 2018-04-18 09:41:24 HD Request # 16 | Download start date-time: 2018-04-17 02:25:36.000 | 2018-04-18 09:41:24 HD Request # 17 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: scdataallservices | 2018-04-18 09:41:24 HD Request # 17 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:41:24 HD Request # 16 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 09:41:24 HD Request # 17 | Using user Barchart Historical data account. | 2018-04-18 09:41:24 HD Request # 17 | Requesting historical Intraday Tick data for YM-201806-ECBOT starting at 2018-04-18 10:40:39 (Exchange time). | 2018-04-18 09:41:24 Socket (347) | Creating socket. | 2018-04-18 09:41:24 Socket (347) | Connecting to IP: 8.18.161.133. | 2018-04-18 09:41:24 HTTPS connection to www.sierrachart.com:443 (346) | Socket gracefully closed by remote side. | 2018-04-18 09:41:24 HTTPS connection to www.sierrachart.com:443 (346) | Initiating close of socket by core. | 2018-04-18 09:41:24 HTTPS connection to www.sierrachart.com:443 (346) | Received socket Close event. | 2018-04-18 09:41:24 HTTPS connection to www.sierrachart.com:443 (346) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 09:41:24 HTTPS connection to www.sierrachart.com:443 (346) | Closed. | 2018-04-18 09:41:24 HTTPS connection to historicaldata.sierrachart.com:443 (348) | Creating socket. Using TLS 1.2. | 2018-04-18 09:41:24 HTTPS connection to historicaldata.sierrachart.com:443 (348) | Connecting to IP: 88.99.0.216. | 2018-04-18 09:41:24 HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-04-18 09:41:24 HD Request # 16 | Sending historical data logon request message. | 2018-04-18 09:41:24 HD Request # 16 | Requesting Intraday data. Start date-time: 2018-04-17 02:25:36. Record interval: 0. Symbol: EMDM18 | 2018-04-18 09:41:24 HD Request # 16 | Decompressing data. | 2018-04-18 09:41:24 HD Request # 16 | Receiving Intraday data for EWM18 starting at 2018-04-17 02:25:36 | 2018-04-18 09:41:24 HD Request # 16 | Timestamp of first Intraday data file record written: 2018-04-17 02:29:34 | 2018-04-18 09:41:24 Socket (347) | Initiating close of socket by core. | 2018-04-18 09:41:24 Socket (347) | Shutdown started. Waiting for graceful close. | 2018-04-18 09:41:24 Historical data download thread signaled to stop. | 2018-04-18 09:41:24 HD Request # 16 | Received 12745 records from 2018-04-17 02:25:36 to 2018-04-18 09:31:24 (31.1 hours) and wrote 12744 records for EWM18 | 2018-04-18 09:41:25 HD Request # 16 | Completion time: 0s | 2018-04-18 09:41:25 HD Request # 16 | Intraday data download complete for EWM18. Unique request ID: 15 | 2018-04-18 09:41:25 Removed historical data download ID 15 | 2018-04-18 09:41:25 Real-time Intraday chart data file updates started for EWM18 | 2018-04-18 09:41:25 Intraday chart data file opened for EWM18 | 2018-04-18 09:41:25 Socket (347) | Socket gracefully closed by remote side. | 2018-04-18 09:41:25 Socket (347) | Closed. | 2018-04-18 09:41:25 HD Request # 17 | Error downloading historical Intraday data for YM-201806-ECBOT. Error executing query: Invalid symbol | 2018-04-18 09:41:26 HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 09:41:26 HD Request # 17 | Completion time: 1s | 2018-04-18 09:41:26 HD Request # 17 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 16 | 2018-04-18 09:41:26 Removed historical data download ID 16 | 2018-04-18 09:41:26 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 09:41:26 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 09:41:26 HD Request # 18 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: scdataallservices | 2018-04-18 09:41:26 HD Request # 18 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:41:26 HD Request # 18 | Using user Barchart Historical data account. | 2018-04-18 09:41:26 HD Request # 18 | Requesting historical Intraday Tick data for NQ-201806-GLOBEX starting at 2018-04-18 10:40:39 (Exchange time). | 2018-04-18 09:41:26 HD Request # 18 | Error downloading historical Intraday data for NQ-201806-GLOBEX. Error executing query: Invalid symbol | 2018-04-18 09:41:27 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 09:41:27 HD Request # 18 | Completion time: 0s | 2018-04-18 09:41:27 HD Request # 18 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 17 | 2018-04-18 09:41:27 Removed historical data download ID 17 | 2018-04-18 09:41:27 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 09:41:27 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 09:41:27 HD Request # 19 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: scdataallservices | 2018-04-18 09:41:27 HD Request # 19 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:41:27 HD Request # 19 | Using user Barchart Historical data account. | 2018-04-18 09:41:27 HD Request # 19 | Requesting historical Intraday Tick data for ES-201806-GLOBEX starting at 2018-04-18 10:40:39 (Exchange time). | 2018-04-18 09:41:27 HD Request # 19 | Error downloading historical Intraday data for ES-201806-GLOBEX. Error executing query: Invalid symbol | 2018-04-18 09:41:29 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 09:41:29 HD Request # 19 | Completion time: 2s | 2018-04-18 09:41:29 HD Request # 19 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 18 | 2018-04-18 09:41:29 Removed historical data download ID 18 | 2018-04-18 09:41:29 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 09:41:29 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 09:41:29 HD Request # 20 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: scdataallservices | 2018-04-18 09:41:29 HD Request # 20 | Performing multistage download. Downloading Minute data first. | 2018-04-18 09:41:29 HD Request # 20 | Download start date-time: 2017-10-14 09:41:28.000 | 2018-04-18 09:41:29 HD Request # 20 | Disabling Intraday chart updating for symbol during historical data download. | 2018-04-18 09:41:29 HD Request # 20 | Using user Barchart Historical data account. | 2018-04-18 09:41:29 HD Request # 20 | Requesting historical Intraday Minute data for TICK-NYSE-IND-NYSE starting at 2017-10-14 10:41:28 (Exchange time). | 2018-04-18 09:41:29 HD Request # 20 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 09:41:30 HD Request # 20 | Completion time: 1s | 2018-04-18 09:41:30 HD Request # 20 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 19 | 2018-04-18 09:41:30 HD Request # 21 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: scdataallservices | 2018-04-18 09:41:30 HD Request # 21 | Rounding start date-time down to the minute: 2017-10-14 09:41:00.000 | 2018-04-18 09:41:30 HD Request # 21 | Download start date-time: 2017-10-14 09:41:00.000 | 2018-04-18 09:41:30 HD Request # 21 | Using user Barchart Historical data account. | 2018-04-18 09:41:30 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-18 10:41:28 (Exchange time). | 2018-04-18 09:41:30 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-19 00:00:00 (Exchange time). | 2018-04-18 09:41:30 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-20 00:00:00 (Exchange time). | 2018-04-18 09:41:31 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-21 00:00:00 (Exchange time). | 2018-04-18 09:41:32 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-22 00:00:00 (Exchange time). | 2018-04-18 09:41:33 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-23 00:00:00 (Exchange time). | 2018-04-18 09:41:34 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-24 00:00:00 (Exchange time). | 2018-04-18 09:41:35 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-25 00:00:00 (Exchange time). | 2018-04-18 09:41:35 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-26 00:00:00 (Exchange time). | 2018-04-18 09:41:36 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-27 00:00:00 (Exchange time). | 2018-04-18 09:41:37 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-28 00:00:00 (Exchange time). | 2018-04-18 09:41:38 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-29 00:00:00 (Exchange time). | 2018-04-18 09:41:39 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-30 00:00:00 (Exchange time). | 2018-04-18 09:41:39 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-31 00:00:00 (Exchange time). | 2018-04-18 09:41:40 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-01 00:00:00 (Exchange time). | 2018-04-18 09:41:41 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-02 00:00:00 (Exchange time). | 2018-04-18 09:41:42 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-03 00:00:00 (Exchange time). | 2018-04-18 09:41:43 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-04 00:00:00 (Exchange time). | 2018-04-18 09:41:43 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-05 00:00:00 (Exchange time). | 2018-04-18 09:41:44 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-06 00:00:00 (Exchange time). | 2018-04-18 09:41:45 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-07 00:00:00 (Exchange time). | 2018-04-18 09:41:46 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-08 00:00:00 (Exchange time). | 2018-04-18 09:41:47 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-09 00:00:00 (Exchange time). | 2018-04-18 09:41:47 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-10 00:00:00 (Exchange time). | 2018-04-18 09:41:48 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-11 00:00:00 (Exchange time). | 2018-04-18 09:41:49 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-12 00:00:00 (Exchange time). | 2018-04-18 09:41:50 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-13 00:00:00 (Exchange time). | 2018-04-18 09:41:51 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-14 00:00:00 (Exchange time). | 2018-04-18 09:41:52 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-15 00:00:00 (Exchange time). | 2018-04-18 09:41:53 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-16 00:00:00 (Exchange time). | 2018-04-18 09:41:54 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-17 00:00:00 (Exchange time). | 2018-04-18 09:41:55 HD Request # 21 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-18 00:00:00 (Exchange time). | 2018-04-18 09:41:56 HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 09:41:57 HD Request # 21 | Completion time: 27s | 2018-04-18 09:41:57 HD Request # 21 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 19 | 2018-04-18 09:41:57 Removed historical data download ID 19 | 2018-04-18 09:41:57 Real-time Intraday chart data file updates started for TICK-NYSE-IND-NYSE | 2018-04-18 09:41:57 Intraday chart data file opened for TICK-NYSE-IND-NYSE | 2018-04-18 09:41:57 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2018-04-18 09:41:57 HD Request # 22 | Downloading Intraday chart data for $TICk to the file $TICk.scid. Service: scdataallservices | 2018-04-18 09:41:57 HD Request # 22 | Download start date-time: 2018-04-16 15:04:00.000 | 2018-04-18 09:41:57 HD Request # 22 | Using user Barchart Historical data account. | 2018-04-18 09:41:57 HD Request # 22 | Requesting historical Intraday Tick data for $TICk starting at 2018-04-16 16:04:00 (Exchange time). | 2018-04-18 09:41:57 HD Request # 22 | Receiving Intraday data for $TICk starting at 2018-04-16 15:04:00 | 2018-04-18 09:41:57 HD Request # 22 | Timestamp of first Intraday data file record written: 2018-04-16 15:04:01 | 2018-04-18 09:41:57 HD Request # 22 | Requesting historical Intraday Tick data for $TICk starting at 2018-04-17 00:00:00 (Exchange time). | 2018-04-18 09:41:57 HD Request # 22 | Requesting historical Intraday Tick data for $TICk starting at 2018-04-18 00:00:00 (Exchange time). | 2018-04-18 09:42:00 HD Request # 22 | Received 27429 records from 2018-04-16 15:04:00 to 2018-04-18 09:32:00 (42.5 hours) and wrote 27428 records for $TICk | 2018-04-18 09:42:02 HD Request # 22 | Completion time: 5s | 2018-04-18 09:42:02 HD Request # 22 | Intraday data download complete for $TICk. Unique request ID: 20 | 2018-04-18 09:42:02 Removed historical data download ID 20 | 2018-04-18 09:42:02 Real-time Intraday chart data file updates started for $TICk | 2018-04-18 09:42:02 Intraday chart data file opened for $TICk | 2018-04-18 09:42:02 SC Data - All Services | Disconnected. | 2018-04-18 09:42:15 SC Data - All Services | Disconnected. | 2018-04-18 09:42:15 Checking for new symbol settings for service code interactive_brokers.trading | 2018-04-18 09:42:15 Current selected Data/Trading service: Interactive Brokers | 2018-04-18 09:42:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-04-18 09:42:15 HTTPS connection to www.sierrachart.com:443 (350) | Creating socket. Using TLS 1.2. | 2018-04-18 09:42:15 HTTPS connection to www.sierrachart.com:443 (350) | Connecting to IP: 204.15.192.108. | 2018-04-18 09:42:15 Requesting symbol settings for service code interactive_brokers.trading. Overwrite = on. | 2018-04-18 09:42:15 Symbol settings received. | 2018-04-18 09:42:16 Processed 1394 symbol settings. | 2018-04-18 09:42:17 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-04-18 09:42:18 Socket (351) | Creating socket. | 2018-04-18 09:42:18 Socket (351) | Connecting to IP: 127.0.0.1. | 2018-04-18 09:42:18 Interactive Brokers | Sending API sign: API | 2018-04-18 09:42:19 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-04-18 09:42:19 Interactive Brokers | TWS server version: 136 | 2018-04-18 09:42:19 Interactive Brokers | TWS time: 20180418 09:42:18 CST | 2018-04-18 09:42:19 Interactive Brokers | Connected. Sending Start API command. | 2018-04-18 09:42:20 Interactive Brokers | Waiting for account information. | 2018-04-18 09:42:20 IB Account information received. | 2018-04-18 09:42:20 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-04-18 09:42:20 Interactive Brokers | Connected to Demo or Simulated account. | 2018-04-18 09:42:20 Interactive Brokers | Not previously connected to Live account. | 2018-04-18 09:42:20 Interactive Brokers | Connected to data and trading server. | 2018-04-18 09:42:20 Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-04-18 09:42:20 Next valid order ID: 1 | 2018-04-18 09:42:20 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 09:42:20 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-04-18 09:42:20 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 09:42:20 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-04-18 09:42:20 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 09:42:20 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-04-18 09:42:20 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 09:42:20 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 09:42:20 Next valid order ID: 1 | 2018-04-18 09:42:20 Interactive Brokers | Starting real-time market data updates for: $TICK. ID: 1 | 2018-04-18 09:42:20 Interactive Brokers | Subscribing to Symbol: $TICK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 09:42:20 Interactive Brokers | Requesting security definition data for: $TICK. ID: 1 | 2018-04-18 09:42:20 Interactive Brokers | Using primary service for historical data for $TICK | 2018-04-18 09:42:20 Intraday data recording state for symbol $TICK is set to download 'Pending'. | 2018-04-18 09:42:20 Delaying start of download for $TICK | 2018-04-18 09:42:20 Interactive Brokers | Starting real-time market data updates for: YM-201806-ECBOT. ID: 2 | 2018-04-18 09:42:20 Interactive Brokers | Subscribing to Symbol: YM, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 09:42:20 Interactive Brokers | Requesting security definition data for: YM-201806-ECBOT. ID: 2 | 2018-04-18 09:42:20 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YM-201806-ECBOT | 2018-04-18 09:42:20 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 09:42:20 Delaying start of download for YM-201806-ECBOT | 2018-04-18 09:42:20 Interactive Brokers | Starting real-time market data updates for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 09:42:20 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 09:42:20 Interactive Brokers | Requesting security definition data for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 09:42:20 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-04-18 09:42:20 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 09:42:20 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 09:42:20 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 09:42:20 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 09:42:20 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-04-18 09:42:20 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 09:42:20 Interactive Brokers | Starting real-time market data updates for: EWM18. ID: 5 | 2018-04-18 09:42:20 Interactive Brokers | Subscribing to Symbol: EWM18, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 09:42:20 Interactive Brokers | Requesting security definition data for: EWM18. ID: 5 | 2018-04-18 09:42:20 Interactive Brokers | Using primary service for historical data for EWM18 | 2018-04-18 09:42:20 Intraday data recording state for symbol EWM18 is set to download 'Pending'. | 2018-04-18 09:42:20 Interactive Brokers | Starting real-time market data updates for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 09:42:20 Interactive Brokers | Subscribing to Symbol: (Using local symbol), SecurityType: IND, Expiration: , Exchange: NYSE, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: TICK-NYSE, TradingClass: | 2018-04-18 09:42:20 Interactive Brokers | Requesting security definition data for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 09:42:20 Interactive Brokers | Using primary service for historical data for TICK-NYSE-IND-NYSE | 2018-04-18 09:42:20 Intraday data recording state for symbol TICK-NYSE-IND-NYSE is set to download 'Pending'. | 2018-04-18 09:42:20 Symbol Error - $TICK is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 09:42:20 Symbol Error - $TICK is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 09:42:20 HTTPS connection to www.sierrachart.com:443 (350) | Socket gracefully closed by remote side. | 2018-04-18 09:42:21 HTTPS connection to www.sierrachart.com:443 (350) | Initiating close of socket by core. | 2018-04-18 09:42:21 HTTPS connection to www.sierrachart.com:443 (350) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 09:42:21 HTTPS connection to www.sierrachart.com:443 (350) | Closed. | 2018-04-18 09:42:21 Interactive Brokers | Market data type is Delayed for YM-201806-ECBOT | 2018-04-18 09:42:21 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 2. Symbol: YM-201806-ECBOT. | 2018-04-18 09:42:21 Interactive Brokers | Market data type is Delayed for NQ-201806-GLOBEX | 2018-04-18 09:42:21 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 3. Symbol: NQ-201806-GLOBEX. | 2018-04-18 09:42:21 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 09:42:21 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 09:42:21 HD Request # 23 | Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: interactive_brokers.trading | 2018-04-18 09:42:21 HD Request # 23 | Download start date-time: 2018-04-18 09:32:00.000 | 2018-04-18 09:42:21 HD Request # 23 | Requesting a total of 0 days and 5420 seconds. | 2018-04-18 09:42:21 HD Request # 23 | IB Backfill - Seconds requested: 5420. Seconds Remaining: 0. | 2018-04-18 09:42:21 HD Request # 23 | Requesting 5420 Seconds of data at 30 secs with ending date-time at 2018-04-18 10:52:20 for $TICK. PriceType: TRADES | 2018-04-18 09:42:21 Interactive Brokers | Market data type is Delayed for ES-201806-GLOBEX | 2018-04-18 09:42:21 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 4. Symbol: ES-201806-GLOBEX. | 2018-04-18 09:42:21 HD Request # 23 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200002. | 2018-04-18 09:42:21 HD Request # 23 | Error downloading historical Intraday data for $TICK. The symbol is unknown to the server. | 2018-04-18 09:42:21 HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TICK | 2018-04-18 09:42:21 HD Request # 23 | Completion time: 1s | 2018-04-18 09:42:21 HD Request # 23 | Intraday data download complete for $TICK. Unique request ID: 21 | 2018-04-18 09:42:21 Removed historical data download ID 21 | 2018-04-18 09:42:21 Real-time Intraday chart data file updates started for $TICK | 2018-04-18 09:42:21 Intraday chart data file opened for $TICK | 2018-04-18 09:42:21 Message from IB: No historical data query found for ticker id:200002. IB Error Code: 366. Request ID: 200002. | 2018-04-18 09:42:21 HD Request # 24 | Downloading Intraday chart data for EWM18 to the file EWM18.scid. Service: interactive_brokers.trading | 2018-04-18 09:42:21 HD Request # 24 | Download start date-time: 2018-04-18 09:31:24.000 | 2018-04-18 09:42:21 HD Request # 24 | Requesting a total of 0 days and 5457 seconds. | 2018-04-18 09:42:21 HD Request # 24 | IB Backfill - Seconds requested: 5457. Seconds Remaining: 0. | 2018-04-18 09:42:21 HD Request # 24 | Requesting 5457 Seconds of data at 30 secs with ending date-time at 2018-04-18 10:52:21 for EWM18. PriceType: TRADES | 2018-04-18 09:42:21 HD Request # 24 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200003. | 2018-04-18 09:42:21 HD Request # 24 | Error downloading historical Intraday data for EWM18. The symbol is unknown to the server. | 2018-04-18 09:42:21 HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EWM18 | 2018-04-18 09:42:21 HD Request # 24 | Completion time: 0s | 2018-04-18 09:42:21 HD Request # 24 | Intraday data download complete for EWM18. Unique request ID: 25 | 2018-04-18 09:42:21 Removed historical data download ID 25 | 2018-04-18 09:42:21 Real-time Intraday chart data file updates started for EWM18 | 2018-04-18 09:42:21 Intraday chart data file opened for EWM18 | 2018-04-18 09:42:21 Delaying start of download for TICK-NYSE-IND-NYSE | 2018-04-18 09:42:21 Message from IB: No historical data query found for ticker id:200003. IB Error Code: 366. Request ID: 200003. | 2018-04-18 09:42:21 Message from IB: Requested market data is not subscribed.Delayed market data is not available.TICK-NYSE NYSE TICK INDEX/TOP/ALL. IB Error Code: 354. Request ID: 6. Symbol: TICK-NYSE-IND-NYSE. | 2018-04-18 09:42:21 Delaying start of download for YM-201806-ECBOT | 2018-04-18 09:42:22 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: DU10* | 2018-04-18 09:42:25 Requesting market depth updates for: ES-201806-GLOBEX if supported. | 2018-04-18 09:42:25 Requesting market depth updates for: EWM18 if supported. | 2018-04-18 09:42:25 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 09:42:25 Requesting market depth updates for: YM-201806-ECBOT if supported. | 2018-04-18 09:42:25 Interactive Brokers | Received Trade Positions download end message for account DU10* | 2018-04-18 09:42:25 Symbol Error - (unknown symbol with ID 100005) is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 09:42:25 Message from IB: Requested market data is not subscribed.Delayed market data is not available.ES JUN'18/DEEP. IB Error Code: 354. Request ID: 100004. | 2018-04-18 09:42:25 Message from IB: Requested market data is not subscribed.Delayed market data is not available.NQ JUN'18/DEEP. IB Error Code: 354. Request ID: 100003. | 2018-04-18 09:42:25 Message from IB: Requested market data is not subscribed.Delayed market data is not available.YM JUN'18/DEEP. IB Error Code: 354. Request ID: 100002. | 2018-04-18 09:42:25 HD Request # 25 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: cbot | 2018-04-18 09:42:26 HD Request # 25 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:42:26 HD Request # 25 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 09:42:26 Socket (352) | Creating socket. | 2018-04-18 09:42:26 Socket (352) | Connecting to IP: 8.18.161.135. | 2018-04-18 09:42:26 HD Request # 25 | Setting DTC encoding to Binary VLS | 2018-04-18 09:42:26 HD Request # 25 | Sending historical data logon request message. | 2018-04-18 09:42:26 HD Request # 25 | Requesting Intraday data. Start date-time: 2018-04-18 09:40:39. Record interval: 0. Symbol: YMM18 | 2018-04-18 09:42:26 HD Request # 25 | Decompressing data. | 2018-04-18 09:42:26 Socket (352) | Initiating close of socket by core. | 2018-04-18 09:42:26 Socket (352) | Shutdown started. Waiting for graceful close. | 2018-04-18 09:42:26 Historical data download thread signaled to stop. | 2018-04-18 09:42:26 HD Request # 25 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 09:42:26 Socket (352) | Socket gracefully closed by remote side. | 2018-04-18 09:42:26 Socket (352) | Closed. | 2018-04-18 09:42:26 HD Request # 25 | Completion time: 1s | 2018-04-18 09:42:26 HD Request # 25 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 22 | 2018-04-18 09:42:26 Removed historical data download ID 22 | 2018-04-18 09:42:26 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 09:42:26 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 09:42:26 Interactive Brokers | Using primary service for historical data for YM-201806-ECBOT | 2018-04-18 09:42:26 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 09:42:26 HD Request # 26 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-04-18 09:42:26 HD Request # 26 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:42:26 HD Request # 26 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 09:42:26 Socket (353) | Creating socket. | 2018-04-18 09:42:26 Socket (353) | Connecting to IP: 8.18.161.133. | 2018-04-18 09:42:26 HD Request # 26 | Setting DTC encoding to Binary VLS | 2018-04-18 09:42:26 HD Request # 26 | Sending historical data logon request message. | 2018-04-18 09:42:26 HD Request # 26 | Requesting Intraday data. Start date-time: 2018-04-18 09:40:39. Record interval: 0. Symbol: NQM18 | 2018-04-18 09:42:26 HD Request # 26 | Decompressing data. | 2018-04-18 09:42:26 Socket (353) | Initiating close of socket by core. | 2018-04-18 09:42:26 Socket (353) | Shutdown started. Waiting for graceful close. | 2018-04-18 09:42:26 Historical data download thread signaled to stop. | 2018-04-18 09:42:26 HD Request # 26 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 09:42:26 HD Request # 26 | Completion time: 0s | 2018-04-18 09:42:26 HD Request # 26 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 23 | 2018-04-18 09:42:26 Removed historical data download ID 23 | 2018-04-18 09:42:26 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 09:42:26 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 09:42:26 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-04-18 09:42:26 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 09:42:26 HD Request # 27 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-04-18 09:42:26 HD Request # 27 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:42:26 HD Request # 27 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 09:42:26 Socket (354) | Creating socket. | 2018-04-18 09:42:26 Socket (354) | Connecting to IP: 8.18.161.135. | 2018-04-18 09:42:26 Socket (353) | Socket gracefully closed by remote side. | 2018-04-18 09:42:26 Socket (353) | Closed. | 2018-04-18 09:42:26 HD Request # 27 | Setting DTC encoding to Binary VLS | 2018-04-18 09:42:27 HD Request # 27 | Sending historical data logon request message. | 2018-04-18 09:42:27 HD Request # 27 | Requesting Intraday data. Start date-time: 2018-04-18 09:40:39. Record interval: 0. Symbol: ESM18 | 2018-04-18 09:42:27 HD Request # 27 | Decompressing data. | 2018-04-18 09:42:27 Socket (354) | Initiating close of socket by core. | 2018-04-18 09:42:27 Socket (354) | Shutdown started. Waiting for graceful close. | 2018-04-18 09:42:27 Historical data download thread signaled to stop. | 2018-04-18 09:42:27 HD Request # 27 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 09:42:27 HD Request # 27 | Completion time: 0s | 2018-04-18 09:42:27 HD Request # 27 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 24 | 2018-04-18 09:42:27 Removed historical data download ID 24 | 2018-04-18 09:42:27 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 09:42:27 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 09:42:27 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-04-18 09:42:27 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 09:42:27 Socket (354) | Socket gracefully closed by remote side. | 2018-04-18 09:42:27 Socket (354) | Closed. | 2018-04-18 09:42:27 HD Request # 28 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: interactive_brokers.trading | 2018-04-18 09:42:31 HD Request # 28 | Download start date-time: 2017-10-14 09:42:31.000 | 2018-04-18 09:42:31 HD Request # 28 | Requesting a total of 21 days and 0 seconds. | 2018-04-18 09:42:31 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2018-04-18 09:42:31 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-29 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:31 HD Request # 28 | Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200004. | 2018-04-18 09:42:32 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1641600. | 2018-04-18 09:42:32 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-30 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:32 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200005. | 2018-04-18 09:42:32 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1555200. | 2018-04-18 09:42:32 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-31 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:32 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200005. | 2018-04-18 09:42:32 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200006. | 2018-04-18 09:42:32 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1468800. | 2018-04-18 09:42:32 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-01 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:32 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200007. | 2018-04-18 09:42:32 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1382400. | 2018-04-18 09:42:32 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-02 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:32 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200006. | 2018-04-18 09:42:32 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200007. | 2018-04-18 09:42:32 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200008. | 2018-04-18 09:42:32 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1296000. | 2018-04-18 09:42:32 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-03 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:32 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200008. | 2018-04-18 09:42:32 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200009. | 2018-04-18 09:42:32 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1209600. | 2018-04-18 09:42:32 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-04 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:32 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200009. | 2018-04-18 09:42:32 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200010. | 2018-04-18 09:42:32 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1123200. | 2018-04-18 09:42:32 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-05 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:32 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200010. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200011. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1036800. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-06 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200011. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200012. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 950400. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-07 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200012. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200013. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 864000. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-08 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200013. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200014. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 777600. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-09 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 * Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200014. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200015. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 691200. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-10 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200016. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 604800. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-11 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200015. | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200016. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200017. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 518400. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-12 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200017. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200018. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 432000. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-13 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200018. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200019. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 345600. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-14 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200019. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200020. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 259200. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-15 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200020. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200021. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 172800. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-16 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200022. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 86400. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-17 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200021. | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200022. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200023. | 2018-04-18 09:42:33 HD Request # 28 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 0. | 2018-04-18 09:42:33 HD Request # 28 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-18 10:52:31 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200023. | 2018-04-18 09:42:33 HD Request # 28 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200024. | 2018-04-18 09:42:33 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 09:42:33 HD Request # 28 | Completion time: 2s | 2018-04-18 09:42:33 HD Request # 28 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 26 | 2018-04-18 09:42:33 Removed historical data download ID 26 | 2018-04-18 09:42:33 Real-time Intraday chart data file updates started for TICK-NYSE-IND-NYSE | 2018-04-18 09:42:33 Intraday chart data file opened for TICK-NYSE-IND-NYSE | 2018-04-18 09:42:33 HD Request # 29 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-04-18 09:42:33 HD Request # 29 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:42:33 HD Request # 29 | Requesting a total of 0 days and 4914 seconds. | 2018-04-18 09:42:33 HD Request # 29 | IB Backfill - Seconds requested: 4914. Seconds Remaining: 0. | 2018-04-18 09:42:33 HD Request # 29 | Requesting 4914 Seconds of data at 30 secs with ending date-time at 2018-04-18 10:52:33 for YM-201806-ECBOT. PriceType: TRADES | 2018-04-18 09:42:33 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200024. | 2018-04-18 09:42:33 HD Request # 29 | Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 200025. | 2018-04-18 09:42:33 HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 09:42:33 HD Request # 29 | Completion time: 0s | 2018-04-18 09:42:33 HD Request # 29 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 27 | 2018-04-18 09:42:33 Removed historical data download ID 27 | 2018-04-18 09:42:33 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 09:42:33 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 09:42:33 HD Request # 30 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 09:42:33 HD Request # 30 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:42:33 HD Request # 30 | Requesting a total of 0 days and 4914 seconds. | 2018-04-18 09:42:33 HD Request # 30 | IB Backfill - Seconds requested: 4914. Seconds Remaining: 0. | 2018-04-18 09:42:33 HD Request # 30 | Requesting 4914 Seconds of data at 30 secs with ending date-time at 2018-04-18 10:52:33 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-04-18 09:42:33 HD Request # 30 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200026. | 2018-04-18 09:42:33 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 09:42:33 HD Request # 30 | Completion time: 0s | 2018-04-18 09:42:33 HD Request # 30 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 28 | 2018-04-18 09:42:33 Removed historical data download ID 28 | 2018-04-18 09:42:33 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 09:42:33 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 09:42:33 HD Request # 31 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 09:42:33 HD Request # 31 | Download start date-time: 2018-04-18 09:40:39.000 | 2018-04-18 09:42:33 HD Request # 31 | Requesting a total of 0 days and 4914 seconds. | 2018-04-18 09:42:33 HD Request # 31 | IB Backfill - Seconds requested: 4914. Seconds Remaining: 0. | 2018-04-18 09:42:33 HD Request # 31 | Requesting 4914 Seconds of data at 30 secs with ending date-time at 2018-04-18 10:52:33 for ES-201806-GLOBEX. PriceType: TRADES | 2018-04-18 09:42:33 HD Request # 31 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200027. | 2018-04-18 09:42:33 HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 09:42:33 HD Request # 31 | Completion time: 0s | 2018-04-18 09:42:33 HD Request # 31 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 29 | 2018-04-18 09:42:33 Removed historical data download ID 29 | 2018-04-18 09:42:33 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 09:42:33 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 09:42:33 Opened cached Intraday file: C:\SierraChart\Data\NQ-201806-GLOBEX.scid | 2018-04-18 09:42:36 Opened cached Intraday file: C:\SierraChart\Data\YM-201806-ECBOT.scid | 2018-04-18 09:42:39 Opened cached Intraday file: C:\SierraChart\Data\ES-201806-GLOBEX.scid | 2018-04-18 09:42:42 HTTPS connection to historicaldata.sierrachart.com:443 (348) | Socket gracefully closed by remote side. | 2018-04-18 09:45:01 HTTPS connection to historicaldata.sierrachart.com:443 (348) | Received socket Close event. | 2018-04-18 09:45:01 HTTPS connection to historicaldata.sierrachart.com:443 (348) | Initiating close of socket by core. | 2018-04-18 09:45:01 HTTPS connection to historicaldata.sierrachart.com:443 (348) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 09:45:01 HTTPS connection to historicaldata.sierrachart.com:443 (348) | Closed. | 2018-04-18 09:45:01 File >> Disconnect selected. | 2018-04-18 10:40:17 Socket (351) | Initiating close of socket by core. | 2018-04-18 10:40:17 Socket (351) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:40:17 Socket (351) | Socket gracefully closed by remote side. | 2018-04-18 10:40:17 Socket (351) | Closed. | 2018-04-18 10:40:17 Interactive Brokers | Disconnected. | 2018-04-18 10:40:18 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-04-18 10:40:34 Socket (414) | Creating socket. | 2018-04-18 10:40:34 Socket (414) | Connecting to IP: 127.0.0.1. | 2018-04-18 10:40:34 Interactive Brokers | Sending API sign: API | 2018-04-18 10:40:34 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-04-18 10:40:34 Interactive Brokers | TWS server version: 136 | 2018-04-18 10:40:34 Interactive Brokers | TWS time: 20180418 10:40:33 CST | 2018-04-18 10:40:34 Interactive Brokers | Connected. Sending Start API command. | 2018-04-18 10:40:35 Interactive Brokers | Waiting for account information. | 2018-04-18 10:40:35 IB Account information received. | 2018-04-18 10:40:35 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-04-18 10:40:35 Interactive Brokers | Connected to Demo or Simulated account. | 2018-04-18 10:40:35 Interactive Brokers | Not previously connected to Live account. | 2018-04-18 10:40:35 Interactive Brokers | Connected to data and trading server. | 2018-04-18 10:40:35 Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-04-18 10:40:35 Next valid order ID: 1 | 2018-04-18 10:40:35 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:40:35 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:40:35 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:40:35 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:40:35 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:40:35 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-04-18 10:40:35 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 10:40:35 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 10:40:35 Next valid order ID: 1 | 2018-04-18 10:40:35 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 1 | 2018-04-18 10:40:35 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:40:35 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 1 | 2018-04-18 10:40:35 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-04-18 10:40:35 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:40:35 Delaying start of download for ES-201806-GLOBEX | 2018-04-18 10:40:35 Interactive Brokers | Starting real-time market data updates for: $TICk. ID: 2 | 2018-04-18 10:40:35 Interactive Brokers | Subscribing to Symbol: $TICk, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:40:35 Interactive Brokers | Requesting security definition data for: $TICk. ID: 2 | 2018-04-18 10:40:35 Interactive Brokers | Using primary service for historical data for $TICk | 2018-04-18 10:40:35 Intraday data recording state for symbol $TICk is set to download 'Pending'. | 2018-04-18 10:40:35 Delaying start of download for $TICk | 2018-04-18 10:40:35 Interactive Brokers | Starting real-time market data updates for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 10:40:35 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:40:35 Interactive Brokers | Requesting security definition data for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 10:40:35 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-04-18 10:40:35 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:40:35 Interactive Brokers | Starting real-time market data updates for: YM-201806-ECBOT. ID: 4 | 2018-04-18 10:40:35 Interactive Brokers | Subscribing to Symbol: YM, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:40:35 Interactive Brokers | Requesting security definition data for: YM-201806-ECBOT. ID: 4 | 2018-04-18 10:40:35 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YM-201806-ECBOT | 2018-04-18 10:40:35 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 10:40:35 Interactive Brokers | Starting real-time market data updates for: EWM18. ID: 5 | 2018-04-18 10:40:35 Interactive Brokers | Subscribing to Symbol: EWM18, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:40:35 Interactive Brokers | Requesting security definition data for: EWM18. ID: 5 | 2018-04-18 10:40:35 Interactive Brokers | Using primary service for historical data for EWM18 | 2018-04-18 10:40:35 Intraday data recording state for symbol EWM18 is set to download 'Pending'. | 2018-04-18 10:40:35 Interactive Brokers | Starting real-time market data updates for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 10:40:35 Interactive Brokers | Subscribing to Symbol: (Using local symbol), SecurityType: IND, Expiration: , Exchange: NYSE, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: TICK-NYSE, TradingClass: | 2018-04-18 10:40:35 Interactive Brokers | Requesting security definition data for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 10:40:35 Interactive Brokers | Using primary service for historical data for TICK-NYSE-IND-NYSE | 2018-04-18 10:40:35 Intraday data recording state for symbol TICK-NYSE-IND-NYSE is set to download 'Pending'. | 2018-04-18 10:40:35 Symbol Error - $TICk is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:40:35 Symbol Error - $TICk is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:40:35 Interactive Brokers | Market data type is Delayed for ES-201806-GLOBEX | 2018-04-18 10:40:35 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 1. Symbol: ES-201806-GLOBEX. | 2018-04-18 10:40:35 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:40:35 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:40:36 Interactive Brokers | Market data type is Delayed for NQ-201806-GLOBEX | 2018-04-18 10:40:36 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 3. Symbol: NQ-201806-GLOBEX. | 2018-04-18 10:40:36 Interactive Brokers | Market data type is Delayed for YM-201806-ECBOT | 2018-04-18 10:40:36 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 4. Symbol: YM-201806-ECBOT. | 2018-04-18 10:40:36 Message from IB: Requested market data is not subscribed.Delayed market data is not available.TICK-NYSE NYSE TICK INDEX/TOP/ALL. IB Error Code: 354. Request ID: 6. Symbol: TICK-NYSE-IND-NYSE. | 2018-04-18 10:40:36 Delaying start of download for ES-201806-GLOBEX | 2018-04-18 10:40:36 HD Request # 32 | Downloading Intraday chart data for $TICk to the file $TICk.scid. Service: interactive_brokers.trading | 2018-04-18 10:40:36 HD Request # 32 | Download start date-time: 2018-04-18 09:32:00.000 | 2018-04-18 10:40:36 HD Request # 32 | Requesting a total of 0 days and 8916 seconds. | 2018-04-18 10:40:36 HD Request # 32 | IB Backfill - Seconds requested: 8916. Seconds Remaining: 0. | 2018-04-18 10:40:36 HD Request # 32 | Requesting 8916 Seconds of data at 30 secs with ending date-time at 2018-04-18 11:50:36 for $TICk. PriceType: TRADES | 2018-04-18 10:40:36 HD Request # 32 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200002. | 2018-04-18 10:40:36 HD Request # 32 | Error downloading historical Intraday data for $TICk. The symbol is unknown to the server. | 2018-04-18 10:40:36 HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TICk | 2018-04-18 10:40:36 HD Request # 32 | Completion time: 0s | 2018-04-18 10:40:36 HD Request # 32 | Intraday data download complete for $TICk. Unique request ID: 31 | 2018-04-18 10:40:36 Removed historical data download ID 31 | 2018-04-18 10:40:36 Real-time Intraday chart data file updates started for $TICk | 2018-04-18 10:40:36 Intraday chart data file opened for $TICk | 2018-04-18 10:40:36 HD Request # 33 | Downloading Intraday chart data for EWM18 to the file EWM18.scid. Service: interactive_brokers.trading | 2018-04-18 10:40:36 HD Request # 33 | Download start date-time: 2018-04-18 09:31:24.000 | 2018-04-18 10:40:36 HD Request # 33 | Requesting a total of 0 days and 8952 seconds. | 2018-04-18 10:40:36 HD Request # 33 | IB Backfill - Seconds requested: 8952. Seconds Remaining: 0. | 2018-04-18 10:40:36 HD Request # 33 | Requesting 8952 Seconds of data at 30 secs with ending date-time at 2018-04-18 11:50:36 for EWM18. PriceType: TRADES | 2018-04-18 10:40:36 Message from IB: No historical data query found for ticker id:200002. IB Error Code: 366. Request ID: 200002. | 2018-04-18 10:40:36 HD Request # 33 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200003. | 2018-04-18 10:40:36 HD Request # 33 | Error downloading historical Intraday data for EWM18. The symbol is unknown to the server. | 2018-04-18 10:40:36 HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EWM18 | 2018-04-18 10:40:36 HD Request # 33 | Completion time: 0s | 2018-04-18 10:40:36 HD Request # 33 | Intraday data download complete for EWM18. Unique request ID: 34 | 2018-04-18 10:40:36 Removed historical data download ID 34 | 2018-04-18 10:40:36 Real-time Intraday chart data file updates started for EWM18 | 2018-04-18 10:40:36 Intraday chart data file opened for EWM18 | 2018-04-18 10:40:36 Delaying start of download for TICK-NYSE-IND-NYSE | 2018-04-18 10:40:36 Message from IB: No historical data query found for ticker id:200003. IB Error Code: 366. Request ID: 200003. | 2018-04-18 10:40:36 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: DU10* | 2018-04-18 10:40:40 Requesting market depth updates for: ES-201806-GLOBEX if supported. | 2018-04-18 10:40:40 Requesting market depth updates for: EWM18 if supported. | 2018-04-18 10:40:40 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 10:40:40 Requesting market depth updates for: YM-201806-ECBOT if supported. | 2018-04-18 10:40:40 Interactive Brokers | Received Trade Positions download end message for account DU10* | 2018-04-18 10:40:40 Symbol Error - (unknown symbol with ID 100005) is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:40:40 Message from IB: Requested market data is not subscribed.Delayed market data is not available.ES JUN'18/DEEP. IB Error Code: 354. Request ID: 100001. | 2018-04-18 10:40:40 Message from IB: Requested market data is not subscribed.Delayed market data is not available.NQ JUN'18/DEEP. IB Error Code: 354. Request ID: 100003. | 2018-04-18 10:40:40 Message from IB: Requested market data is not subscribed.Delayed market data is not available.YM JUN'18/DEEP. IB Error Code: 354. Request ID: 100004. | 2018-04-18 10:40:40 HD Request # 34 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-04-18 10:40:40 HD Request # 34 | Download start date-time: 2018-04-18 10:40:14.000 | 2018-04-18 10:40:40 HD Request # 34 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 10:40:40 Socket (415) | Creating socket. | 2018-04-18 10:40:40 Socket (415) | Connecting to IP: 8.18.161.133. | 2018-04-18 10:40:40 HD Request # 34 | Setting DTC encoding to Binary VLS | 2018-04-18 10:40:40 HD Request # 34 | Sending historical data logon request message. | 2018-04-18 10:40:40 HD Request # 34 | Requesting Intraday data. Start date-time: 2018-04-18 10:40:14. Record interval: 0. Symbol: ESM18 | 2018-04-18 10:40:40 HD Request # 34 | Decompressing data. | 2018-04-18 10:40:40 Socket (415) | Initiating close of socket by core. | 2018-04-18 10:40:40 Socket (415) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:40:40 Historical data download thread signaled to stop. | 2018-04-18 10:40:40 HD Request # 34 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 10:40:40 HD Request # 34 | Completion time: 0s | 2018-04-18 10:40:40 HD Request # 34 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 30 | 2018-04-18 10:40:40 Removed historical data download ID 30 | 2018-04-18 10:40:40 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 10:40:40 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 10:40:40 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-04-18 10:40:40 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:40:40 HD Request # 35 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-04-18 10:40:40 HD Request # 35 | Download start date-time: 2018-04-18 10:40:14.000 | 2018-04-18 10:40:40 HD Request # 35 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 10:40:40 Socket (416) | Creating socket. | 2018-04-18 10:40:40 Socket (416) | Connecting to IP: 8.18.161.135. | 2018-04-18 10:40:40 Socket (415) | Socket gracefully closed by remote side. | 2018-04-18 10:40:40 Socket (415) | Closed. | 2018-04-18 10:40:40 HD Request # 35 | Setting DTC encoding to Binary VLS | 2018-04-18 10:40:40 HD Request # 35 | Sending historical data logon request message. | 2018-04-18 10:40:40 HD Request # 35 | Requesting Intraday data. Start date-time: 2018-04-18 10:40:14. Record interval: 0. Symbol: NQM18 | 2018-04-18 10:40:40 HD Request # 35 | Decompressing data. | 2018-04-18 10:40:40 Socket (416) | Initiating close of socket by core. | 2018-04-18 10:40:40 Socket (416) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:40:40 Historical data download thread signaled to stop. | 2018-04-18 10:40:40 HD Request # 35 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 10:40:40 HD Request # 35 | Completion time: 0s | 2018-04-18 10:40:40 HD Request # 35 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 32 | 2018-04-18 10:40:40 Removed historical data download ID 32 | 2018-04-18 10:40:40 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 10:40:40 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 10:40:40 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-04-18 10:40:40 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:40:40 HD Request # 36 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: cbot | 2018-04-18 10:40:40 HD Request # 36 | Download start date-time: 2018-04-18 10:40:13.000 | 2018-04-18 10:40:40 Socket (416) | Socket gracefully closed by remote side. | 2018-04-18 10:40:41 Socket (416) | Closed. | 2018-04-18 10:40:41 HD Request # 36 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 10:40:41 Socket (417) | Creating socket. | 2018-04-18 10:40:41 Socket (417) | Connecting to IP: 8.18.161.133. | 2018-04-18 10:40:41 HD Request # 36 | Setting DTC encoding to Binary VLS | 2018-04-18 10:40:41 HD Request # 36 | Sending historical data logon request message. | 2018-04-18 10:40:41 HD Request # 36 | Requesting Intraday data. Start date-time: 2018-04-18 10:40:13. Record interval: 0. Symbol: YMM18 | 2018-04-18 10:40:41 HD Request # 36 | Decompressing data. | 2018-04-18 10:40:41 Socket (417) | Initiating close of socket by core. | 2018-04-18 10:40:41 Socket (417) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:40:41 Historical data download thread signaled to stop. | 2018-04-18 10:40:41 HD Request # 36 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 10:40:41 HD Request # 36 | Completion time: 0s | 2018-04-18 10:40:41 HD Request # 36 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 33 | 2018-04-18 10:40:41 Removed historical data download ID 33 | 2018-04-18 10:40:41 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 10:40:41 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 10:40:41 Interactive Brokers | Using primary service for historical data for YM-201806-ECBOT | 2018-04-18 10:40:41 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 10:40:41 Socket (417) | Socket gracefully closed by remote side. | 2018-04-18 10:40:41 Socket (417) | Closed. | 2018-04-18 10:40:41 HD Request # 37 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: interactive_brokers.trading | 2018-04-18 10:40:46 HD Request # 37 | Download start date-time: 2017-10-14 10:40:46.000 | 2018-04-18 10:40:46 HD Request # 37 | Requesting a total of 21 days and 0 seconds. | 2018-04-18 10:40:46 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2018-04-18 10:40:46 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-29 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:46 HD Request # 37 | Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200004. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1641600. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-30 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200005. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1555200. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-31 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200005. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200006. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1468800. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-01 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200006. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200007. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1382400. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-02 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200007. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200008. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1296000. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-03 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200008. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200009. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1209600. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-04 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200009. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200010. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1123200. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-05 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200010. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200011. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1036800. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-06 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200011. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200012. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 950400. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-07 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200012. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200013. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 864000. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-08 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200013. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200014. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 777600. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-09 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 * Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200014. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200015. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 691200. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-10 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200015. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200016. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 604800. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-11 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200016. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200017. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 518400. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-12 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200017. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200018. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 432000. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-13 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200018. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200019. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 345600. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-14 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200020. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 259200. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-15 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200019. | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200020. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200021. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 172800. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-16 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:47 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200021. | 2018-04-18 10:40:47 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200022. | 2018-04-18 10:40:47 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 86400. | 2018-04-18 10:40:47 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-17 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:48 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200022. | 2018-04-18 10:40:48 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200023. | 2018-04-18 10:40:48 HD Request # 37 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 0. | 2018-04-18 10:40:48 HD Request # 37 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-18 11:50:46 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:40:48 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200023. | 2018-04-18 10:40:48 HD Request # 37 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200024. | 2018-04-18 10:40:48 HD Request # 37 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 10:40:48 HD Request # 37 | Completion time: 1s | 2018-04-18 10:40:48 HD Request # 37 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 35 | 2018-04-18 10:40:48 Removed historical data download ID 35 | 2018-04-18 10:40:48 Real-time Intraday chart data file updates started for TICK-NYSE-IND-NYSE | 2018-04-18 10:40:48 Intraday chart data file opened for TICK-NYSE-IND-NYSE | 2018-04-18 10:40:48 HD Request # 38 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 10:40:48 HD Request # 38 | Download start date-time: 2018-04-18 10:40:14.000 | 2018-04-18 10:40:48 HD Request # 38 | Requesting a total of 0 days and 4833 seconds. | 2018-04-18 10:40:48 HD Request # 38 | IB Backfill - Seconds requested: 4833. Seconds Remaining: 0. | 2018-04-18 10:40:48 HD Request # 38 | Requesting 4833 Seconds of data at 30 secs with ending date-time at 2018-04-18 11:50:47 for ES-201806-GLOBEX. PriceType: TRADES | 2018-04-18 10:40:48 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200024. | 2018-04-18 10:40:48 HD Request # 38 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200025. | 2018-04-18 10:40:48 HD Request # 38 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 10:40:48 HD Request # 38 | Completion time: 0s | 2018-04-18 10:40:48 HD Request # 38 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 36 | 2018-04-18 10:40:48 Removed historical data download ID 36 | 2018-04-18 10:40:48 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 10:40:48 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 10:40:48 HD Request # 39 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 10:40:48 HD Request # 39 | Download start date-time: 2018-04-18 10:40:14.000 | 2018-04-18 10:40:48 HD Request # 39 | Requesting a total of 0 days and 4833 seconds. | 2018-04-18 10:40:48 HD Request # 39 | IB Backfill - Seconds requested: 4833. Seconds Remaining: 0. | 2018-04-18 10:40:48 HD Request # 39 | Requesting 4833 Seconds of data at 30 secs with ending date-time at 2018-04-18 11:50:47 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-04-18 10:40:48 HD Request # 39 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200026. | 2018-04-18 10:40:48 HD Request # 39 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 10:40:48 HD Request # 39 | Completion time: 0s | 2018-04-18 10:40:48 HD Request # 39 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 37 | 2018-04-18 10:40:48 Removed historical data download ID 37 | 2018-04-18 10:40:48 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 10:40:48 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 10:40:48 HD Request # 40 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-04-18 10:40:48 HD Request # 40 | Download start date-time: 2018-04-18 10:40:13.000 | 2018-04-18 10:40:48 HD Request # 40 | Requesting a total of 0 days and 4834 seconds. | 2018-04-18 10:40:48 HD Request # 40 | IB Backfill - Seconds requested: 4834. Seconds Remaining: 0. | 2018-04-18 10:40:48 HD Request # 40 | Requesting 4834 Seconds of data at 30 secs with ending date-time at 2018-04-18 11:50:47 for YM-201806-ECBOT. PriceType: TRADES | 2018-04-18 10:40:48 HD Request # 40 | Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 200027. | 2018-04-18 10:40:48 HD Request # 40 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 10:40:48 HD Request # 40 | Completion time: 0s | 2018-04-18 10:40:48 HD Request # 40 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 38 | 2018-04-18 10:40:48 Removed historical data download ID 38 | 2018-04-18 10:40:48 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 10:40:48 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 10:40:48 Opened cached Intraday file: C:\SierraChart\Data\ES-201806-GLOBEX.scid | 2018-04-18 10:40:50 Opened cached Intraday file: C:\SierraChart\Data\NQ-201806-GLOBEX.scid | 2018-04-18 10:40:50 Opened cached Intraday file: C:\SierraChart\Data\YM-201806-ECBOT.scid | 2018-04-18 10:40:50 $NQCE 2 Min #1 | Reloading chart. | 2018-04-18 10:41:14 $NQCE 2 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$NQCE.scid | 2018-04-18 10:41:15 Unsubscribed from market depth data for NQ-201806-GLOBEX | 2018-04-18 10:41:15 Interactive Brokers | Starting real-time market data updates for: $NQCE. ID: 7 | 2018-04-18 10:41:15 Interactive Brokers | Subscribing to Symbol: $NQCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:41:15 Interactive Brokers | Requesting security definition data for: $NQCE. ID: 7 | 2018-04-18 10:41:15 Requesting market depth updates for: $NQCE if supported. | 2018-04-18 10:41:15 Message from IB: Can't find the subscribed market depth with tickerId:100003. IB Error Code: 310. Request ID: 100003. | 2018-04-18 10:41:15 Symbol Error - $NQCE is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:41:15 Symbol Error - (unknown symbol with ID 100007) is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:41:15 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: $NQCE | 2018-04-18 10:41:15 Intraday data recording state for symbol $NQCE is set to download 'Pending'. | 2018-04-18 10:41:15 Symbol Error - $NQCE is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:41:15 HD Request # 41 | Downloading Intraday chart data for $NQCE to the file $NQCE.scid. Service: nasdaq.index | 2018-04-18 10:41:15 Compressing file: C:\SierraChart\Data\$NQCE.scid. This may take a while. | 2018-04-18 10:41:15 HD Request # 41 | Download start date-time: 2017-10-14 10:41:15.000 | 2018-04-18 10:41:15 HD Request # 41 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 10:41:15 Socket (418) | Creating socket. | 2018-04-18 10:41:15 Socket (418) | Connecting to IP: 8.18.161.135. | 2018-04-18 10:41:15 HD Request # 41 | Setting DTC encoding to Binary VLS | 2018-04-18 10:41:15 HD Request # 41 | Sending historical data logon request message. | 2018-04-18 10:41:15 HD Request # 41 | Requesting Intraday data. Start date-time: 2017-10-14 10:41:15. Record interval: 0. Symbol: $NQCE | 2018-04-18 10:41:15 HD Request # 41 | Decompressing data. | 2018-04-18 10:41:15 HD Request # 41 | Receiving Intraday data for $NQCE starting at 2017-10-16 08:30:15 | 2018-04-18 10:41:15 HD Request # 41 | Timestamp of first Intraday data file record written: 2017-10-16 08:30:15 | 2018-04-18 10:41:15 Socket (418) | Initiating close of socket by core. | 2018-04-18 10:41:21 Socket (418) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:41:21 Historical data download thread signaled to stop. | 2018-04-18 10:41:21 HD Request # 41 | Received 3517221 records from 2017-10-16 08:30:15 to 2018-04-18 10:26:15 (184.1 days) and wrote 3517221 records for $NQCE | 2018-04-18 10:41:21 HD Request # 41 | Completion time: 6s | 2018-04-18 10:41:21 HD Request # 41 | Intraday data download complete for $NQCE. Unique request ID: 39 | 2018-04-18 10:41:21 Removed historical data download ID 39 | 2018-04-18 10:41:21 Real-time Intraday chart data file updates started for $NQCE | 2018-04-18 10:41:21 Intraday chart data file opened for $NQCE | 2018-04-18 10:41:21 Interactive Brokers | Using primary service for historical data for $NQCE | 2018-04-18 10:41:21 Intraday data recording state for symbol $NQCE is set to download 'Pending'. | 2018-04-18 10:41:21 HD Request # 42 | Downloading Intraday chart data for $NQCE to the file $NQCE.scid. Service: nasdaq.index | 2018-04-18 10:41:21 HD Request # 42 | Download start date-time: 2018-04-18 10:26:15.000 | 2018-04-18 10:41:21 HD Request # 42 | Requesting a total of 0 days and 5706 seconds. | 2018-04-18 10:41:21 HD Request # 42 | IB Backfill - Seconds requested: 5706. Seconds Remaining: 0. | 2018-04-18 10:41:21 HD Request # 42 | Requesting 5706 Seconds of data at 30 secs with ending date-time at 2018-04-18 11:51:21 for $NQCE. PriceType: TRADES | 2018-04-18 10:41:21 Socket (418) | Socket gracefully closed by remote side. | 2018-04-18 10:41:21 Socket (418) | Closed. | 2018-04-18 10:41:21 HD Request # 42 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200028. | 2018-04-18 10:41:21 HD Request # 42 | Error downloading historical Intraday data for $NQCE. The symbol is unknown to the server. | 2018-04-18 10:41:21 HD Request # 42 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $NQCE | 2018-04-18 10:41:21 HD Request # 42 | Completion time: 0s | 2018-04-18 10:41:21 HD Request # 42 | Intraday data download complete for $NQCE. Unique request ID: 40 | 2018-04-18 10:41:21 Removed historical data download ID 40 | 2018-04-18 10:41:21 Real-time Intraday chart data file updates started for $NQCE | 2018-04-18 10:41:21 Intraday chart data file opened for $NQCE | 2018-04-18 10:41:21 Message from IB: No historical data query found for ticker id:200028. IB Error Code: 366. Request ID: 200028. | 2018-04-18 10:41:21 NQ-201806-GLOBEX 2 Min #1 | Reloading chart. | 2018-04-18 10:42:11 Unsubscribed from market depth data for $NQCE | 2018-04-18 10:42:15 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 10:42:15 Message from IB: Can't find the subscribed market depth with tickerId:100007. IB Error Code: 310. Request ID: 100007. | 2018-04-18 10:42:15 Message from IB: Requested market data is not subscribed.Delayed market data is not available.NQ JUN'18/DEEP. IB Error Code: 354. Request ID: 100003. | 2018-04-18 10:42:15 Socket (414) | Initiating close of socket by core. | 2018-04-18 10:50:31 Socket (414) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:50:31 Interactive Brokers | Disconnected. | 2018-04-18 10:50:31 Socket (414) | Socket gracefully closed by remote side. | 2018-04-18 10:50:31 Socket (414) | Closed. | 2018-04-18 10:50:31 Checking for new symbol settings for service code scdataallservices | 2018-04-18 10:50:31 Current selected Data/Trading service: SC Data - All Services | 2018-04-18 10:50:31 HTTPS connection to www.sierrachart.com:443 (428) | Creating socket. Using TLS 1.2. | 2018-04-18 10:50:31 HTTPS connection to www.sierrachart.com:443 (428) | Connecting to IP: 204.15.192.108. | 2018-04-18 10:50:31 SC Data - All Services | Disconnected. | 2018-04-18 10:50:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-04-18 10:50:31 SC Data - All Services | Connected to data server. | 2018-04-18 10:50:34 Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-04-18 10:50:34 SC Data - All Services | Starting real-time market data updates for: NQ-201806-GLOBEX. ID: 1 | 2018-04-18 10:50:35 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQ-201806-GLOBEX | 2018-04-18 10:50:35 SC Data - All Services | Requesting security definition data for: NQ-201806-GLOBEX. ID: 1 | 2018-04-18 10:50:35 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:50:35 Delaying start of download for NQ-201806-GLOBEX | 2018-04-18 10:50:35 SC Data - All Services | Starting real-time market data updates for: YM-201806-ECBOT. ID: 2 | 2018-04-18 10:50:35 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: YM-201806-ECBOT | 2018-04-18 10:50:35 SC Data - All Services | Requesting security definition data for: YM-201806-ECBOT. ID: 2 | 2018-04-18 10:50:35 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 10:50:35 SC Data - All Services | Starting real-time market data updates for: EWM18. ID: 3 | 2018-04-18 10:50:35 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: EWM18 | 2018-04-18 10:50:35 SC Data - All Services | Requesting security definition data for: EWM18. ID: 3 | 2018-04-18 10:50:35 Intraday data recording state for symbol EWM18 is set to download 'Pending'. | 2018-04-18 10:50:35 Delaying start of download for EWM18 | 2018-04-18 10:50:35 SC Data - All Services | Starting real-time market data updates for: $TICK. ID: 4 | 2018-04-18 10:50:35 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: $TICK | 2018-04-18 10:50:35 SC Data - All Services | Requesting security definition data for: $TICK. ID: 4 | 2018-04-18 10:50:35 Intraday data recording state for symbol $TICK is set to download 'Pending'. | 2018-04-18 10:50:35 SC Data - All Services | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 5 | 2018-04-18 10:50:35 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ES-201806-GLOBEX | 2018-04-18 10:50:35 SC Data - All Services | Requesting security definition data for: ES-201806-GLOBEX. ID: 5 | 2018-04-18 10:50:35 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:50:35 SC Data - All Services | Starting real-time market data updates for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 10:50:35 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: TICK-NYSE-IND-NYSE | 2018-04-18 10:50:35 SC Data - All Services | Requesting security definition data for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 10:50:35 Intraday data recording state for symbol TICK-NYSE-IND-NYSE is set to download 'Pending'. | 2018-04-18 10:50:35 Requesting symbol settings for service code scdataallservices. Overwrite = on. | 2018-04-18 10:50:35 Delaying start of download for NQ-201806-GLOBEX | 2018-04-18 10:50:36 Delaying start of download for EWM18 | 2018-04-18 10:50:36 Symbol settings received. | 2018-04-18 10:50:39 HTTPS connection to www.sierrachart.com:443 (428) | Socket gracefully closed by remote side. | 2018-04-18 10:50:44 HTTPS connection to www.sierrachart.com:443 (428) | Received socket Close event. | 2018-04-18 10:50:44 Processed 5574 symbol settings. | 2018-04-18 10:50:45 It is recommended to reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed' | 2018-04-18 10:50:45 HTTPS connection to www.sierrachart.com:443 (428) | Initiating close of socket by core. | 2018-04-18 10:50:45 HTTPS connection to www.sierrachart.com:443 (428) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 10:50:45 HTTPS connection to www.sierrachart.com:443 (428) | Closed. | 2018-04-18 10:50:45 Requesting market depth updates for: ES-201806-GLOBEX if supported. | 2018-04-18 10:50:45 Requesting market depth updates for: EWM18 if supported. | 2018-04-18 10:50:45 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 10:50:45 Requesting market depth updates for: YM-201806-ECBOT if supported. | 2018-04-18 10:50:45 HD Request # 43 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: scdataallservices | 2018-04-18 10:50:45 HD Request # 43 | Download start date-time: 2018-04-18 10:50:28.000 | 2018-04-18 10:50:45 HD Request # 43 | Using user Barchart Historical data account. | 2018-04-18 10:50:45 HD Request # 43 | Requesting historical Intraday Tick data for NQ-201806-GLOBEX starting at 2018-04-18 11:50:28 (Exchange time). | 2018-04-18 10:50:45 HD Request # 44 | Downloading Intraday chart data for EWM18 to the file EWM18.scid. Service: cme | 2018-04-18 10:50:45 HD Request # 44 | Download start date-time: 2018-04-18 09:31:24.000 | 2018-04-18 10:50:45 HD Request # 44 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 10:50:45 Socket (431) | Creating socket. | 2018-04-18 10:50:45 Socket (431) | Connecting to IP: 8.18.161.133. | 2018-04-18 10:50:45 HTTPS connection to historicaldata.sierrachart.com:443 (430) | Creating socket. Using TLS 1.2. | 2018-04-18 10:50:45 HTTPS connection to historicaldata.sierrachart.com:443 (430) | Connecting to IP: 88.99.0.216. | 2018-04-18 10:50:45 HD Request # 44 | Setting DTC encoding to Binary VLS | 2018-04-18 10:50:45 HD Request # 44 | Sending historical data logon request message. | 2018-04-18 10:50:45 HD Request # 44 | Requesting Intraday data. Start date-time: 2018-04-18 09:31:24. Record interval: 0. Symbol: EMDM18 | 2018-04-18 10:50:45 HD Request # 44 | Decompressing data. | 2018-04-18 10:50:45 HD Request # 44 | Receiving Intraday data for EWM18 starting at 2018-04-18 09:31:24 | 2018-04-18 10:50:46 HD Request # 44 | Timestamp of first Intraday data file record written: 2018-04-18 09:31:26 | 2018-04-18 10:50:46 Socket (431) | Initiating close of socket by core. | 2018-04-18 10:50:46 Socket (431) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:50:46 Historical data download thread signaled to stop. | 2018-04-18 10:50:46 HD Request # 44 | Received 1345 records from 2018-04-18 09:31:24 to 2018-04-18 10:40:45 (69.4 minutes) and wrote 1343 records for EWM18 | 2018-04-18 10:50:46 HD Request # 44 | Completion time: 0s | 2018-04-18 10:50:46 HD Request # 44 | Intraday data download complete for EWM18. Unique request ID: 43 | 2018-04-18 10:50:46 Removed historical data download ID 43 | 2018-04-18 10:50:46 Real-time Intraday chart data file updates started for EWM18 | 2018-04-18 10:50:46 Intraday chart data file opened for EWM18 | 2018-04-18 10:50:46 Socket (431) | Socket gracefully closed by remote side. | 2018-04-18 10:50:46 Socket (431) | Closed. | 2018-04-18 10:50:46 HD Request # 43 | Error downloading historical Intraday data for NQ-201806-GLOBEX. Error executing query: Invalid symbol | 2018-04-18 10:50:47 HD Request # 43 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 10:50:47 HD Request # 43 | Completion time: 0s | 2018-04-18 10:50:47 HD Request # 43 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 41 | 2018-04-18 10:50:47 Removed historical data download ID 41 | 2018-04-18 10:50:47 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 10:50:47 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 10:50:47 HD Request # 45 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: scdataallservices | 2018-04-18 10:50:47 HD Request # 45 | Download start date-time: 2018-04-18 10:50:27.000 | 2018-04-18 10:50:47 HD Request # 45 | Using user Barchart Historical data account. | 2018-04-18 10:50:47 HD Request # 45 | Requesting historical Intraday Tick data for YM-201806-ECBOT starting at 2018-04-18 11:50:27 (Exchange time). | 2018-04-18 10:50:47 HD Request # 45 | Error downloading historical Intraday data for YM-201806-ECBOT. Error executing query: Invalid symbol | 2018-04-18 10:50:54 HD Request # 45 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 10:50:54 HD Request # 45 | Completion time: 8s | 2018-04-18 10:50:54 HD Request # 45 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 42 | 2018-04-18 10:50:54 Removed historical data download ID 42 | 2018-04-18 10:50:54 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 10:50:54 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 10:50:54 HD Request # 46 | Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: scdataallservices | 2018-04-18 10:50:54 HD Request # 46 | Download start date-time: 2018-04-18 09:32:00.000 | 2018-04-18 10:50:54 HD Request # 46 | Using user Barchart Historical data account. | 2018-04-18 10:50:54 HD Request # 46 | Requesting historical Intraday Tick data for $TICK starting at 2018-04-18 10:32:00 (Exchange time). | 2018-04-18 10:50:54 HD Request # 46 | Receiving Intraday data for $TICK starting at 2018-04-18 09:32:00 | 2018-04-18 10:50:58 HD Request # 46 | Timestamp of first Intraday data file record written: 2018-04-18 09:32:01 | 2018-04-18 10:50:58 HD Request # 46 | Received 4122 records from 2018-04-18 09:32:00 to 2018-04-18 10:40:56 (68.9 minutes) and wrote 4121 records for $TICK | 2018-04-18 10:50:58 HD Request # 46 | Completion time: 3s | 2018-04-18 10:50:58 HD Request # 46 | Intraday data download complete for $TICK. Unique request ID: 44 | 2018-04-18 10:50:58 Removed historical data download ID 44 | 2018-04-18 10:50:58 Real-time Intraday chart data file updates started for $TICK | 2018-04-18 10:50:58 Intraday chart data file opened for $TICK | 2018-04-18 10:50:58 HD Request # 47 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: scdataallservices | 2018-04-18 10:50:58 HD Request # 47 | Download start date-time: 2018-04-18 10:50:28.000 | 2018-04-18 10:50:58 HD Request # 47 | Using user Barchart Historical data account. | 2018-04-18 10:50:58 HD Request # 47 | Requesting historical Intraday Tick data for ES-201806-GLOBEX starting at 2018-04-18 11:50:28 (Exchange time). | 2018-04-18 10:50:58 HD Request # 47 | Error downloading historical Intraday data for ES-201806-GLOBEX. Error executing query: Invalid symbol | 2018-04-18 10:50:59 HD Request # 47 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 10:50:59 HD Request # 47 | Completion time: 1s | 2018-04-18 10:50:59 HD Request # 47 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 45 | 2018-04-18 10:50:59 Removed historical data download ID 45 | 2018-04-18 10:50:59 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 10:50:59 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 10:50:59 HD Request # 48 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: scdataallservices | 2018-04-18 10:50:59 HD Request # 48 | Performing multistage download. Downloading Minute data first. | 2018-04-18 10:50:59 HD Request # 48 | Download start date-time: 2017-10-14 10:50:58.000 | 2018-04-18 10:50:59 HD Request # 48 | Disabling Intraday chart updating for symbol during historical data download. | 2018-04-18 10:50:59 HD Request # 48 | Using user Barchart Historical data account. | 2018-04-18 10:50:59 HD Request # 48 | Requesting historical Intraday Minute data for TICK-NYSE-IND-NYSE starting at 2017-10-14 11:50:58 (Exchange time). | 2018-04-18 10:50:59 HD Request # 48 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 10:50:59 HD Request # 48 | Completion time: 1s | 2018-04-18 10:50:59 HD Request # 48 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 46 | 2018-04-18 10:50:59 HD Request # 49 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: scdataallservices | 2018-04-18 10:50:59 HD Request # 49 | Rounding start date-time down to the minute: 2017-10-14 10:50:00.000 | 2018-04-18 10:50:59 HD Request # 49 | Download start date-time: 2017-10-14 10:50:00.000 | 2018-04-18 10:50:59 HD Request # 49 | Using user Barchart Historical data account. | 2018-04-18 10:50:59 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-18 11:50:58 (Exchange time). | 2018-04-18 10:50:59 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-19 00:00:00 (Exchange time). | 2018-04-18 10:51:00 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-20 00:00:00 (Exchange time). | 2018-04-18 10:51:01 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-21 00:00:00 (Exchange time). | 2018-04-18 10:51:02 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-22 00:00:00 (Exchange time). | 2018-04-18 10:51:03 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-23 00:00:00 (Exchange time). | 2018-04-18 10:51:03 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-24 00:00:00 (Exchange time). | 2018-04-18 10:51:04 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-25 00:00:00 (Exchange time). | 2018-04-18 10:51:05 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-26 00:00:00 (Exchange time). | 2018-04-18 10:51:06 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-27 00:00:00 (Exchange time). | 2018-04-18 10:51:06 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-28 00:00:00 (Exchange time). | 2018-04-18 10:51:07 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-29 00:00:00 (Exchange time). | 2018-04-18 10:51:08 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-30 00:00:00 (Exchange time). | 2018-04-18 10:51:09 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-03-31 00:00:00 (Exchange time). | 2018-04-18 10:51:10 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-01 00:00:00 (Exchange time). | 2018-04-18 10:51:11 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-02 00:00:00 (Exchange time). | 2018-04-18 10:51:11 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-03 00:00:00 (Exchange time). | 2018-04-18 10:51:12 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-04 00:00:00 (Exchange time). | 2018-04-18 10:51:13 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-05 00:00:00 (Exchange time). | 2018-04-18 10:51:14 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-06 00:00:00 (Exchange time). | 2018-04-18 10:51:15 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-07 00:00:00 (Exchange time). | 2018-04-18 10:51:15 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-08 00:00:00 (Exchange time). | 2018-04-18 10:51:16 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-09 00:00:00 (Exchange time). | 2018-04-18 10:51:17 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-10 00:00:00 (Exchange time). | 2018-04-18 10:51:18 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-11 00:00:00 (Exchange time). | 2018-04-18 10:51:18 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-12 00:00:00 (Exchange time). | 2018-04-18 10:51:19 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-13 00:00:00 (Exchange time). | 2018-04-18 10:51:20 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-14 00:00:00 (Exchange time). | 2018-04-18 10:51:21 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-15 00:00:00 (Exchange time). | 2018-04-18 10:51:22 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-16 00:00:00 (Exchange time). | 2018-04-18 10:51:23 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-17 00:00:00 (Exchange time). | 2018-04-18 10:51:23 HD Request # 49 | Requesting historical Intraday Tick data for TICK-NYSE-IND-NYSE starting at 2018-04-18 00:00:00 (Exchange time). | 2018-04-18 10:51:24 HD Request # 49 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 10:51:25 HD Request # 49 | Completion time: 25s | 2018-04-18 10:51:25 HD Request # 49 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 46 | 2018-04-18 10:51:25 Removed historical data download ID 46 | 2018-04-18 10:51:25 Real-time Intraday chart data file updates started for TICK-NYSE-IND-NYSE | 2018-04-18 10:51:25 Intraday chart data file opened for TICK-NYSE-IND-NYSE | 2018-04-18 10:51:25 HD Request # 49 | Enabling Intraday chart updating for symbol. | 2018-04-18 10:51:25 HTTPS connection to historicaldata.sierrachart.com:443 (430) | Socket gracefully closed by remote side. | 2018-04-18 10:54:25 HTTPS connection to historicaldata.sierrachart.com:443 (430) | Received socket Close event. | 2018-04-18 10:54:25 HTTPS connection to historicaldata.sierrachart.com:443 (430) | Initiating close of socket by core. | 2018-04-18 10:54:25 HTTPS connection to historicaldata.sierrachart.com:443 (430) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 10:54:25 HTTPS connection to historicaldata.sierrachart.com:443 (430) | Closed. | 2018-04-18 10:54:25 SC Data - All Services | Disconnected. | 2018-04-18 10:58:01 SC Data - All Services | Disconnected. | 2018-04-18 10:58:01 Checking for new symbol settings for service code interactive_brokers.trading | 2018-04-18 10:58:01 Current selected Data/Trading service: Interactive Brokers | 2018-04-18 10:58:01 HTTPS connection to www.sierrachart.com:443 (439) | Creating socket. Using TLS 1.2. | 2018-04-18 10:58:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-04-18 10:58:01 HTTPS connection to www.sierrachart.com:443 (439) | Connecting to IP: 204.15.192.108. | 2018-04-18 10:58:01 Requesting symbol settings for service code interactive_brokers.trading. Overwrite = on. | 2018-04-18 10:58:01 Symbol settings received. | 2018-04-18 10:58:01 Processed 1394 symbol settings. | 2018-04-18 10:58:03 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2018-04-18 10:58:04 Socket (440) | Creating socket. | 2018-04-18 10:58:04 Socket (440) | Connecting to IP: 127.0.0.1. | 2018-04-18 10:58:04 Interactive Brokers | Sending API sign: API | 2018-04-18 10:58:04 Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-04-18 10:58:04 Interactive Brokers | TWS server version: 136 | 2018-04-18 10:58:04 Interactive Brokers | TWS time: 20180418 10:58:03 CST | 2018-04-18 10:58:04 Interactive Brokers | Connected. Sending Start API command. | 2018-04-18 10:58:05 Interactive Brokers | Waiting for account information. | 2018-04-18 10:58:05 IB Account information received. | 2018-04-18 10:58:05 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-04-18 10:58:05 Interactive Brokers | Connected to Demo or Simulated account. | 2018-04-18 10:58:05 Interactive Brokers | Not previously connected to Live account. | 2018-04-18 10:58:05 Interactive Brokers | Connected to data and trading server. | 2018-04-18 10:58:05 Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-04-18 10:58:05 Next valid order ID: 1 | 2018-04-18 10:58:05 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:58:05 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:58:05 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:58:05 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:58:05 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-04-18 10:58:05 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-04-18 10:58:05 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 10:58:05 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-04-18 10:58:05 Next valid order ID: 1 | 2018-04-18 10:58:05 Interactive Brokers | Starting real-time market data updates for: $TICK. ID: 1 | 2018-04-18 10:58:05 Interactive Brokers | Subscribing to Symbol: $TICK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:58:05 Interactive Brokers | Requesting security definition data for: $TICK. ID: 1 | 2018-04-18 10:58:05 Interactive Brokers | Using primary service for historical data for $TICK | 2018-04-18 10:58:05 Intraday data recording state for symbol $TICK is set to download 'Pending'. | 2018-04-18 10:58:05 Delaying start of download for $TICK | 2018-04-18 10:58:05 Interactive Brokers | Starting real-time market data updates for: YM-201806-ECBOT. ID: 2 | 2018-04-18 10:58:05 Interactive Brokers | Subscribing to Symbol: YM, SecurityType: FUT, Expiration: 201806, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:58:05 Interactive Brokers | Requesting security definition data for: YM-201806-ECBOT. ID: 2 | 2018-04-18 10:58:05 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YM-201806-ECBOT | 2018-04-18 10:58:05 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 10:58:05 Delaying start of download for YM-201806-ECBOT | 2018-04-18 10:58:05 Interactive Brokers | Starting real-time market data updates for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 10:58:05 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:58:05 Interactive Brokers | Requesting security definition data for: NQ-201806-GLOBEX. ID: 3 | 2018-04-18 10:58:05 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201806-GLOBEX | 2018-04-18 10:58:05 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:58:05 Interactive Brokers | Starting real-time market data updates for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 10:58:05 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201806, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:58:05 Interactive Brokers | Requesting security definition data for: ES-201806-GLOBEX. ID: 4 | 2018-04-18 10:58:05 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ES-201806-GLOBEX | 2018-04-18 10:58:05 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:58:05 Interactive Brokers | Starting real-time market data updates for: EWM18. ID: 5 | 2018-04-18 10:58:05 Interactive Brokers | Subscribing to Symbol: EWM18, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-04-18 10:58:05 Interactive Brokers | Requesting security definition data for: EWM18. ID: 5 | 2018-04-18 10:58:05 Interactive Brokers | Using primary service for historical data for EWM18 | 2018-04-18 10:58:05 Intraday data recording state for symbol EWM18 is set to download 'Pending'. | 2018-04-18 10:58:05 Symbol Error - $TICK is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:58:05 Interactive Brokers | Starting real-time market data updates for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 10:58:05 Interactive Brokers | Subscribing to Symbol: (Using local symbol), SecurityType: IND, Expiration: , Exchange: NYSE, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: TICK-NYSE, TradingClass: | 2018-04-18 10:58:05 Interactive Brokers | Requesting security definition data for: TICK-NYSE-IND-NYSE. ID: 6 | 2018-04-18 10:58:05 Interactive Brokers | Using primary service for historical data for TICK-NYSE-IND-NYSE | 2018-04-18 10:58:05 Intraday data recording state for symbol TICK-NYSE-IND-NYSE is set to download 'Pending'. | 2018-04-18 10:58:05 Symbol Error - $TICK is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:58:05 Interactive Brokers | Market data type is Delayed for YM-201806-ECBOT | 2018-04-18 10:58:05 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 2. Symbol: YM-201806-ECBOT. | 2018-04-18 10:58:05 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:58:05 Symbol Error - EWM18 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:58:05 Interactive Brokers | Market data type is Delayed for NQ-201806-GLOBEX | 2018-04-18 10:58:05 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 3. Symbol: NQ-201806-GLOBEX. | 2018-04-18 10:58:05 Interactive Brokers | Market data type is Delayed for ES-201806-GLOBEX | 2018-04-18 10:58:05 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 4. Symbol: ES-201806-GLOBEX. | 2018-04-18 10:58:05 Message from IB: Requested market data is not subscribed.Delayed market data is not available.TICK-NYSE NYSE TICK INDEX/TOP/ALL. IB Error Code: 354. Request ID: 6. Symbol: TICK-NYSE-IND-NYSE. | 2018-04-18 10:58:05 HD Request # 50 | Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: interactive_brokers.trading | 2018-04-18 10:58:06 HD Request # 50 | Download start date-time: 2018-04-18 10:40:56.000 | 2018-04-18 10:58:06 HD Request # 50 | Requesting a total of 0 days and 5829 seconds. | 2018-04-18 10:58:06 HD Request # 50 | IB Backfill - Seconds requested: 5829. Seconds Remaining: 0. | 2018-04-18 10:58:06 HD Request # 50 | Requesting 5829 Seconds of data at 30 secs with ending date-time at 2018-04-18 12:08:05 for $TICK. PriceType: TRADES | 2018-04-18 10:58:06 HD Request # 50 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200002. | 2018-04-18 10:58:06 HD Request # 50 | Error downloading historical Intraday data for $TICK. The symbol is unknown to the server. | 2018-04-18 10:58:06 HD Request # 50 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TICK | 2018-04-18 10:58:06 HD Request # 50 | Completion time: 0s | 2018-04-18 10:58:06 HD Request # 50 | Intraday data download complete for $TICK. Unique request ID: 47 | 2018-04-18 10:58:06 Removed historical data download ID 47 | 2018-04-18 10:58:06 Real-time Intraday chart data file updates started for $TICK | 2018-04-18 10:58:06 Intraday chart data file opened for $TICK | 2018-04-18 10:58:06 HD Request # 51 | Downloading Intraday chart data for EWM18 to the file EWM18.scid. Service: interactive_brokers.trading | 2018-04-18 10:58:06 HD Request # 51 | Download start date-time: 2018-04-18 10:40:45.000 | 2018-04-18 10:58:06 HD Request # 51 | Requesting a total of 0 days and 5840 seconds. | 2018-04-18 10:58:06 HD Request # 51 | IB Backfill - Seconds requested: 5840. Seconds Remaining: 0. | 2018-04-18 10:58:06 HD Request # 51 | Requesting 5840 Seconds of data at 30 secs with ending date-time at 2018-04-18 12:08:05 for EWM18. PriceType: TRADES | 2018-04-18 10:58:06 Message from IB: No historical data query found for ticker id:200002. IB Error Code: 366. Request ID: 200002. | 2018-04-18 10:58:06 HD Request # 51 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200003. | 2018-04-18 10:58:06 HD Request # 51 | Error downloading historical Intraday data for EWM18. The symbol is unknown to the server. | 2018-04-18 10:58:06 HD Request # 51 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EWM18 | 2018-04-18 10:58:06 HD Request # 51 | Completion time: 0s | 2018-04-18 10:58:06 HD Request # 51 | Intraday data download complete for EWM18. Unique request ID: 51 | 2018-04-18 10:58:06 Removed historical data download ID 51 | 2018-04-18 10:58:06 Real-time Intraday chart data file updates started for EWM18 | 2018-04-18 10:58:06 Intraday chart data file opened for EWM18 | 2018-04-18 10:58:06 Delaying start of download for TICK-NYSE-IND-NYSE | 2018-04-18 10:58:06 Message from IB: No historical data query found for ticker id:200003. IB Error Code: 366. Request ID: 200003. | 2018-04-18 10:58:06 HTTPS connection to www.sierrachart.com:443 (439) | Socket gracefully closed by remote side. | 2018-04-18 10:58:06 HTTPS connection to www.sierrachart.com:443 (439) | Received socket Close event. | 2018-04-18 10:58:06 HTTPS connection to www.sierrachart.com:443 (439) | Initiating close of socket by core. | 2018-04-18 10:58:06 HTTPS connection to www.sierrachart.com:443 (439) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-04-18 10:58:06 HTTPS connection to www.sierrachart.com:443 (439) | Closed. | 2018-04-18 10:58:06 Delaying start of download for YM-201806-ECBOT | 2018-04-18 10:58:07 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: DU10* | 2018-04-18 10:58:10 Requesting market depth updates for: ES-201806-GLOBEX if supported. | 2018-04-18 10:58:10 Requesting market depth updates for: EWM18 if supported. | 2018-04-18 10:58:10 Requesting market depth updates for: NQ-201806-GLOBEX if supported. | 2018-04-18 10:58:10 Requesting market depth updates for: YM-201806-ECBOT if supported. | 2018-04-18 10:58:10 Interactive Brokers | Received Trade Positions download end message for account DU10* | 2018-04-18 10:58:10 Symbol Error - (unknown symbol with ID 100005) is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-04-18 10:58:10 Message from IB: Requested market data is not subscribed.Delayed market data is not available.ES JUN'18/DEEP. IB Error Code: 354. Request ID: 100004. | 2018-04-18 10:58:10 Message from IB: Requested market data is not subscribed.Delayed market data is not available.NQ JUN'18/DEEP. IB Error Code: 354. Request ID: 100003. | 2018-04-18 10:58:10 Message from IB: Requested market data is not subscribed.Delayed market data is not available.YM JUN'18/DEEP. IB Error Code: 354. Request ID: 100002. | 2018-04-18 10:58:10 HD Request # 52 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: cbot | 2018-04-18 10:58:11 HD Request # 52 | Download start date-time: 2018-04-18 10:50:27.000 | 2018-04-18 10:58:11 HD Request # 52 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 10:58:11 Socket (441) | Creating socket. | 2018-04-18 10:58:11 Socket (441) | Connecting to IP: 8.18.161.135. | 2018-04-18 10:58:11 HD Request # 52 | Setting DTC encoding to Binary VLS | 2018-04-18 10:58:11 HD Request # 52 | Sending historical data logon request message. | 2018-04-18 10:58:11 HD Request # 52 | Requesting Intraday data. Start date-time: 2018-04-18 10:50:27. Record interval: 0. Symbol: YMM18 | 2018-04-18 10:58:11 HD Request # 52 | Decompressing data. | 2018-04-18 10:58:11 Socket (441) | Initiating close of socket by core. | 2018-04-18 10:58:11 Socket (441) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:58:11 Historical data download thread signaled to stop. | 2018-04-18 10:58:11 HD Request # 52 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 10:58:11 HD Request # 52 | Completion time: 1s | 2018-04-18 10:58:11 HD Request # 52 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 48 | 2018-04-18 10:58:11 Removed historical data download ID 48 | 2018-04-18 10:58:11 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 10:58:11 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 10:58:11 Interactive Brokers | Using primary service for historical data for YM-201806-ECBOT | 2018-04-18 10:58:11 Intraday data recording state for symbol YM-201806-ECBOT is set to download 'Pending'. | 2018-04-18 10:58:11 HD Request # 53 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: cme | 2018-04-18 10:58:11 HD Request # 53 | Download start date-time: 2018-04-18 10:50:28.000 | 2018-04-18 10:58:11 Socket (441) | Socket gracefully closed by remote side. | 2018-04-18 10:58:11 Socket (441) | Closed. | 2018-04-18 10:58:11 HD Request # 53 | Using server: ds7.sierracharts.com port 10149 | 2018-04-18 10:58:11 Socket (442) | Creating socket. | 2018-04-18 10:58:11 Socket (442) | Connecting to IP: 8.18.161.133. | 2018-04-18 10:58:11 HD Request # 53 | Setting DTC encoding to Binary VLS | 2018-04-18 10:58:11 HD Request # 53 | Sending historical data logon request message. | 2018-04-18 10:58:11 HD Request # 53 | Requesting Intraday data. Start date-time: 2018-04-18 10:50:28. Record interval: 0. Symbol: NQM18 | 2018-04-18 10:58:11 HD Request # 53 | Decompressing data. | 2018-04-18 10:58:11 Socket (442) | Initiating close of socket by core. | 2018-04-18 10:58:11 Socket (442) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:58:11 Historical data download thread signaled to stop. | 2018-04-18 10:58:11 HD Request # 53 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 10:58:11 HD Request # 53 | Completion time: 0s | 2018-04-18 10:58:11 HD Request # 53 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 49 | 2018-04-18 10:58:11 Removed historical data download ID 49 | 2018-04-18 10:58:11 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 10:58:11 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 10:58:11 Interactive Brokers | Using primary service for historical data for NQ-201806-GLOBEX | 2018-04-18 10:58:11 Intraday data recording state for symbol NQ-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:58:11 HD Request # 54 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: cme | 2018-04-18 10:58:11 HD Request # 54 | Download start date-time: 2018-04-18 10:50:28.000 | 2018-04-18 10:58:11 HD Request # 54 | Using server: ds1.sierracharts.com port 10150 | 2018-04-18 10:58:11 Socket (443) | Creating socket. | 2018-04-18 10:58:11 Socket (443) | Connecting to IP: 8.18.161.135. | 2018-04-18 10:58:11 Socket (442) | Socket gracefully closed by remote side. | 2018-04-18 10:58:11 Socket (442) | Closed. | 2018-04-18 10:58:11 HD Request # 54 | Setting DTC encoding to Binary VLS | 2018-04-18 10:58:11 HD Request # 54 | Sending historical data logon request message. | 2018-04-18 10:58:11 HD Request # 54 | Requesting Intraday data. Start date-time: 2018-04-18 10:50:28. Record interval: 0. Symbol: ESM18 | 2018-04-18 10:58:11 HD Request # 54 | Decompressing data. | 2018-04-18 10:58:11 Socket (443) | Initiating close of socket by core. | 2018-04-18 10:58:11 Socket (443) | Shutdown started. Waiting for graceful close. | 2018-04-18 10:58:11 Historical data download thread signaled to stop. | 2018-04-18 10:58:11 HD Request # 54 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 10:58:11 HD Request # 54 | Completion time: 0s | 2018-04-18 10:58:11 HD Request # 54 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 50 | 2018-04-18 10:58:11 Removed historical data download ID 50 | 2018-04-18 10:58:11 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 10:58:11 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 10:58:11 Interactive Brokers | Using primary service for historical data for ES-201806-GLOBEX | 2018-04-18 10:58:11 Intraday data recording state for symbol ES-201806-GLOBEX is set to download 'Pending'. | 2018-04-18 10:58:11 Socket (443) | Socket gracefully closed by remote side. | 2018-04-18 10:58:11 Socket (443) | Closed. | 2018-04-18 10:58:11 HD Request # 55 | Downloading Intraday chart data for TICK-NYSE-IND-NYSE to the file TICK-NYSE-IND-NYSE.scid. Service: interactive_brokers.trading | 2018-04-18 10:58:16 HD Request # 55 | Download start date-time: 2017-10-14 10:58:16.000 | 2018-04-18 10:58:16 HD Request # 55 | Requesting a total of 21 days and 0 seconds. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-29 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 HD Request # 55 | Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200004. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1641600. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-30 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200005. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1555200. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-03-31 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200005. | 2018-04-18 10:58:16 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200006. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1468800. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-01 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200006. | 2018-04-18 10:58:16 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200007. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1382400. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-02 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200008. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1296000. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-03 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200007. | 2018-04-18 10:58:16 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200008. | 2018-04-18 10:58:16 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200009. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1209600. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-04 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200009. | 2018-04-18 10:58:16 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200010. | 2018-04-18 10:58:16 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1123200. | 2018-04-18 10:58:16 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-05 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:16 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200010. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200011. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1036800. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-06 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200011. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200012. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 950400. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-07 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200012. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200013. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 864000. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-08 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200013. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200014. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 777600. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-09 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 * Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200014. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200015. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 691200. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-10 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200015. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200016. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 604800. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-11 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200016. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200017. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 518400. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-12 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200017. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200018. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 432000. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-13 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200018. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200019. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 345600. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-14 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200019. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200020. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 259200. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-15 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200020. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200021. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 172800. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-16 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200021. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200022. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 86400. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-17 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200022. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200023. | 2018-04-18 10:58:17 HD Request # 55 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 0. | 2018-04-18 10:58:17 HD Request # 55 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-04-18 12:08:16 for TICK-NYSE-IND-NYSE. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200023. | 2018-04-18 10:58:17 HD Request # 55 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 200024. | 2018-04-18 10:58:17 HD Request # 55 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE-IND-NYSE | 2018-04-18 10:58:17 HD Request # 55 | Completion time: 0s | 2018-04-18 10:58:17 HD Request # 55 | Intraday data download complete for TICK-NYSE-IND-NYSE. Unique request ID: 52 | 2018-04-18 10:58:17 Removed historical data download ID 52 | 2018-04-18 10:58:17 Real-time Intraday chart data file updates started for TICK-NYSE-IND-NYSE | 2018-04-18 10:58:17 Intraday chart data file opened for TICK-NYSE-IND-NYSE | 2018-04-18 10:58:17 HD Request # 56 | Downloading Intraday chart data for YM-201806-ECBOT to the file YM-201806-ECBOT.scid. Service: interactive_brokers.trading | 2018-04-18 10:58:17 HD Request # 56 | Download start date-time: 2018-04-18 10:50:27.000 | 2018-04-18 10:58:17 HD Request # 56 | Requesting a total of 0 days and 5269 seconds. | 2018-04-18 10:58:17 HD Request # 56 | IB Backfill - Seconds requested: 5269. Seconds Remaining: 0. | 2018-04-18 10:58:17 HD Request # 56 | Requesting 5269 Seconds of data at 30 secs with ending date-time at 2018-04-18 12:08:16 for YM-201806-ECBOT. PriceType: TRADES | 2018-04-18 10:58:17 Message from IB: Historical Market Data Service error message:No market data permissions for NYSE IND. IB Error Code: 162. Request ID: 200024. | 2018-04-18 10:58:17 HD Request # 56 | Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 200025. | 2018-04-18 10:58:17 HD Request # 56 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201806-ECBOT | 2018-04-18 10:58:17 HD Request # 56 | Completion time: 1s | 2018-04-18 10:58:17 HD Request # 56 | Intraday data download complete for YM-201806-ECBOT. Unique request ID: 53 | 2018-04-18 10:58:17 Removed historical data download ID 53 | 2018-04-18 10:58:17 Real-time Intraday chart data file updates started for YM-201806-ECBOT | 2018-04-18 10:58:17 Intraday chart data file opened for YM-201806-ECBOT | 2018-04-18 10:58:17 HD Request # 57 | Downloading Intraday chart data for NQ-201806-GLOBEX to the file NQ-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 10:58:17 HD Request # 57 | Download start date-time: 2018-04-18 10:50:28.000 | 2018-04-18 10:58:17 HD Request # 57 | Requesting a total of 0 days and 5269 seconds. | 2018-04-18 10:58:17 HD Request # 57 | IB Backfill - Seconds requested: 5269. Seconds Remaining: 0. | 2018-04-18 10:58:17 HD Request # 57 | Requesting 5269 Seconds of data at 30 secs with ending date-time at 2018-04-18 12:08:17 for NQ-201806-GLOBEX. PriceType: TRADES | 2018-04-18 10:58:17 HD Request # 57 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200026. | 2018-04-18 10:58:17 HD Request # 57 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201806-GLOBEX | 2018-04-18 10:58:17 HD Request # 57 | Completion time: 0s | 2018-04-18 10:58:17 HD Request # 57 | Intraday data download complete for NQ-201806-GLOBEX. Unique request ID: 54 | 2018-04-18 10:58:17 Removed historical data download ID 54 | 2018-04-18 10:58:17 Real-time Intraday chart data file updates started for NQ-201806-GLOBEX | 2018-04-18 10:58:17 Intraday chart data file opened for NQ-201806-GLOBEX | 2018-04-18 10:58:17 HD Request # 58 | Downloading Intraday chart data for ES-201806-GLOBEX to the file ES-201806-GLOBEX.scid. Service: interactive_brokers.trading | 2018-04-18 10:58:17 HD Request # 58 | Download start date-time: 2018-04-18 10:50:28.000 | 2018-04-18 10:58:17 HD Request # 58 | Requesting a total of 0 days and 5269 seconds. | 2018-04-18 10:58:17 HD Request # 58 | IB Backfill - Seconds requested: 5269. Seconds Remaining: 0. | 2018-04-18 10:58:17 HD Request # 58 | Requesting 5269 Seconds of data at 30 secs with ending date-time at 2018-04-18 12:08:17 for ES-201806-GLOBEX. PriceType: TRADES | 2018-04-18 10:58:17 HD Request # 58 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 200027. | 2018-04-18 10:58:17 HD Request # 58 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201806-GLOBEX | 2018-04-18 10:58:17 HD Request # 58 | Completion time: 0s | 2018-04-18 10:58:17 HD Request # 58 | Intraday data download complete for ES-201806-GLOBEX. Unique request ID: 55 | 2018-04-18 10:58:17 Removed historical data download ID 55 | 2018-04-18 10:58:17 Real-time Intraday chart data file updates started for ES-201806-GLOBEX | 2018-04-18 10:58:17 Intraday chart data file opened for ES-201806-GLOBEX | 2018-04-18 10:58:17 Opened cached Intraday file: C:\SierraChart\Data\YM-201806-ECBOT.scid | 2018-04-18 10:58:19 Opened cached Intraday file: C:\SierraChart\Data\NQ-201806-GLOBEX.scid | 2018-04-18 10:58:19 Opened cached Intraday file: C:\SierraChart\Data\ES-201806-GLOBEX.scid | 2018-04-18 10:58:25 Sierra Chart Support |
[2018-04-18 19:24:09] |
This is the problem: Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-04-18 04:10:21
Next valid order ID: 1 | 2018-04-18 04:10:21 Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
