Date/Time: Wed, 09 Sep 2026 15:41:51 +0000
Crude Oil Open Price
View Count: 3093
| [2013-10-07 23:33:46] |
| User76055 - Posts: 18 |
I am currently using Zenfire for data and am trying to replicate the official CLX3 Open price of Oct 4 of 102.92 with either DAILY OHLC or HORIZONTAL LINE AT TIME studies but both are showing incorrect prices compared to http://www.mypivots.com/dailynotes/symbol/719/-1/nymex-light-sweet-crude-oil-november-2013 Can you help? Thanks |
| [2013-10-07 23:51:14] |
You will get the accurate open price by opening a Historical Daily chart through File >> Find Symbol. You can have the Daily OHLC study reference that chart through its study inputs.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-08 04:10:58
| [2013-10-08 01:47:00] |
It Works, thanks! Now trying to do same but only show Globex High/Low. I opened an Intraday session and changed the hours and it shows correctly there but cant reference it to show on other charts as the High and Low numbers come up wrong. Thanks |
| Attachment Deleted. |
| [2013-10-08 04:14:08] |
For this maybe you will want to use the High/Low for Time Period study.
| [2013-11-12 15:21:07] |
| Carol Rutherford - Posts: 66 |
Where can I find the symbol for light sweet crude?
| [2013-11-12 16:48:50] |
You can find it through File >> Find Symbol >> Futures.
| [2013-11-12 20:10:19] |
i found the symbol for light sweet crude CL but what format do I put it in sierra chart so it will pull up. For instance with the dow I have to input INDU-I-NYSE or the nasdaq comp-I-nasdq. I assume i wold have to put in the nymes along with CL but don't know the exact format. Thanks or your help |
| [2013-11-12 21:00:12] |
What version of Sierra Chart are you running? You just simply expand the CL list and all of the Futures contract months will list out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-11-13 04:23:27] |
Attached is an image of what you should see if you go to File >> Find Symbol.
