Date/Time: Sun, 19 Jan 2025 15:17:05 +0000
crashing when adding custom study
View Count: 732
[2018-04-18 07:10:33] |
canyiah - Posts: 48 |
Sierra is crashing everytime I try to add a custom study using ver 1727
[2018-04-18 07:37:35] |
This means there is a problem with the custom study. Refer to help topic 17 about this: Http://www.sierrachart.com/index.php?page=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-18 11:21:04] |
I build successfully no warnings I dont even get to select a file before it crashes no warning or windows messages occurs it immediately closes and i have to manually restart
Date Time Of Last Edit: 2018-04-18 11:44:12
[2018-04-18 18:52:58] |
It sounds like there is a problem with one of the custom study DLL files you are using. You need to follow through the instructions at 17.1 here: http://www.sierrachart.com/index.php?page=doc/helpdetails17.html#h17.1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
