Date/Time: Sun, 19 Jan 2025 15:12:58 +0000
3steps trailing stop?
View Count: 772
[2018-04-17 16:31:11]
Diana - Posts: 42
can sierra chart do like this? from NinjaTrader.
Thank you.
Profit 70tick trailing 30tick
Profit100tick trailing 20tick
Profit120tick trailing 15tick
image360截图20180418001300756.jpg / V - Attached On 2018-04-17 16:31:02 UTC - Size: 62.19 KB - 382 views
[2018-04-17 19:13:08]
Yes multiple Attached Orders are supported. Follow the instructions here:
Attached Orders: Step-By-Step Instructions
Here is the documentation for trailing stops:
Order Types: Trailing Stop
[2018-04-19 00:40:36]
Diana - Posts: 42
I've go through the help, can not understand where to set, pls specific ,tks.
how to set exactly like the image I attached?
[2018-04-19 00:45:31]
Diana - Posts: 42
Can't do it ,says I'm Wrong.
image360截图20180419084432843.jpg / V - Attached On 2018-04-19 00:45:14 UTC - Size: 114.3 KB - 342 views
[2018-04-19 04:50:52]
Zdislav - Posts: 73
Check order quantity for entry. You need at least 3 contracts for this setting to work.
[2018-04-19 20:01:25]
Refer to our response here about this:
just one order filled, how to set 3 step trailing stop like below?
[2018-04-20 03:00:38]
Diana - Posts: 42
My god. refer to my reply. tks.
[2018-04-20 18:26:44]
Yes, we did and we responded.
