Date/Time: Thu, 25 Apr 2024 08:37:38 +0000
How to get an alert for market open?
View Count: 1256
[2018-04-17 16:29:23] |
Diana - Posts: 42 |
How to get an alert for market open? and set like this, a time board?
360截图20180418002551401.jpg / V - Attached On 2018-04-17 16:29:02 UTC - Size: 318.62 KB - 437 views |
[2018-04-17 19:00:46] |
The closest that would be available would be the Time Line study: Time Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-18 05:06:31] |
Bedhog - Posts: 167 |
The amazing CLOCX will give you exactly what you need. See the attached picture and .wav files.
Date Time Of Last Edit: 2018-04-18 06:38:20
clocx-clock.JPG / V - Attached On 2018-04-18 05:02:34 UTC - Size: 194.87 KB - 543 views OpeningBell.wav - Attached On 2018-04-18 05:05:11 UTC - Size: 1.39 MB - 319 views ClosingBell.wav - Attached On 2018-04-18 05:05:23 UTC - Size: 15.61 KB - 315 views |
[2019-08-24 17:51:10] |
SK819618 - Posts: 9 |
Support, Is there a script that can be inputted into the alerts tab of the Clock -RealTime study? I'm pouring through the guide to piecemeal the script but I'm not very code savvy. So far I'm seeing IsWeekend() and GetTimeHMS() but not quite sure how to use that for the purpose of activating my opening bell .wav file that is linked to one of the alerts in the general settings/alerts. I'm trying to see if I can get the Clock - RealTime Study to alert me at 9:29:59 and at 15:59:59 Monday - Friday Not an urgent matter. If you do get to it, much appreciated. UPDATE: I did a re-search of the documentation to find the Alert Manager and Time Alerts so no further assistance is required. Appreciate all the thorough documentation. Cheers. Date Time Of Last Edit: 2019-08-24 18:07:24
