Date/Time: Sun, 19 Jan 2025 15:05:01 +0000
Session time auto RTH?
View Count: 857
[2018-04-17 14:33:41] |
Diana - Posts: 42 |
Can session time automatically RTH instead of manual set for every chart?
[2018-04-17 18:53:15] |
Refer to this section here about this: Global Symbol Settings: Setting of Intraday Chart Session Times You can set the Session Times in the Global Symbol Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-19 11:30:06] |
Diana - Posts: 42 |
Where to set automatic RTH rather manually every symbol?
[2018-04-19 18:58:17] |
You can do this in the Global Settings >> Symbol Settings. This is documented here: Global Symbol Settings: Setting of Intraday Chart Session Times However, after you do that, you do have to apply the global settings to each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-19 18:58:26
