Date/Time: Sun, 19 Jan 2025 15:11:46 +0000
PC latency vs CQG latency
View Count: 1367
[2018-04-17 05:57:47] |
Revan - Posts: 9 |
Hello I'm based in Australia and trading US markets Globex/Nymex etc, in the chart settings > latency I'm wondering if this latency is referring to computer latency in processing the data, or latency via distance of data being sent? Also are you aware of anyone based internationally who has had issues with live data streaming, thanks. |
[2018-04-17 06:49:31] |
We do not know what Chart Setting you are referring to. Also are you aware of anyone based internationally who has had issues with live data streaming, thanks. Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-17 06:49:44
[2018-04-17 07:33:21] |
Revan - Posts: 9 |
No charts, I don't use charts, just the trading DOM. the latency setting, where you enter the milliseconds, under chart settings.
Date Time Of Last Edit: 2018-04-17 07:34:18
[2018-04-17 09:29:34] |
That is fully documented here: General Settings Window: Chart Update Interval (Global Settings >> General Settings >> General >> Update Intervals) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
