Date/Time: Sun, 19 Jan 2025 15:14:12 +0000
[Programming Help] - Alert Condition Help
View Count: 931
[2018-04-16 16:41:44]
User153269 - Posts: 7
I'm not sure if this question is appropriate for the support board. Please advise if it isn't.
I am using the Color Bar Based On Alert Condition with the syntax =AND(ID4.SG1<=20,C > O, AV-BV < 0) to show delta divergence within the context of overbought/oversold conditions (ID4.SG1 is the oscillator). In addition to this I want to filter for a momentum signal (ID7.SG1) to occur within n period of bars after these conditions are met. Could you please advise on the additional syntax for the alert?
Regards
Date Time Of Last Edit: 2019-01-17 00:14:26
[2018-04-16 20:35:22]
This is appropriate for the Support Board but we ourselves do not provide alert formula programming. A user may help.
Date Time Of Last Edit: 2018-04-16 20:35:40
[2018-04-16 20:50:12]
Sawtooth - Posts: 4157
Brandon, what you want to do would require a spreadsheet study, or ACSIL, because you need to create a persistent variable of the delta alert so you can wait n bars for the momentum signal.
