Date/Time: Sun, 19 Jan 2025 15:09:39 +0000
DTC Protocol, last traded price and Heartbeat
View Count: 738
[2018-04-16 11:59:11]
User942837 - Posts: 108
Hi, I noticed, that I am receiving JSON messages depending to how fast I am sending heartbeats from client. If I set it to 5seconds, I will not receive data in between those 5 seconds. I thought that this is not the way it should work and was under the impression that the data is being received in realtime not in 5 seconds batches. Please correct me if I am wrong.
If I reduce the client heartbeat to 1s intervals, I receive the last price (message 112) faster but it still is not good enough.
thank you
[2018-04-16 12:13:15]
You really have to look at your code. A problem like this would be on your side.
We tested using compact JSON across instances of Sierra Chart and this is what we see for the symbol EURUSD:
{"Type":3,"F":[0,1523880720]} | 2018-04-16 08:12:01 (Heartbeat)
{"Type":117,"F":[1,1.237169981,1,1.237169981,1,1523880724]} | 2018-04-16 08:12:04
{"Type":117,"F":[1,1.23715996742,1,1.237169981,1,1523880724]} | 2018-04-16 08:12:04
{"Type":117,"F":[1,1.23714995384,1,1.237169981,1,1523880724]} | 2018-04-16 08:12:04
{"Type":117,"F":[1,1.23714995384,1,1.23715996742,1,1523880724]} | 2018-04-16 08:12:04
{"Type":117,"F":[1,1.23714005947,1,1.23715996742,1,1523880724]} | 2018-04-16 08:12:04
{"Type":117,"F":[1,1.23714995384,1,1.23715996742,1,1523880725]} | 2018-04-16 08:12:06
{"Type":117,"F":[1,1.23714995384,1,1.237169981,1,1523880726]} | 2018-04-16 08:12:07
{"Type":117,"F":[1,1.23715996742,1,1.237169981,1,1523880726]} | 2018-04-16 08:12:07
{"Type":117,"F":[1,1.23714995384,1,1.23715996742,1,1523880729]} | 2018-04-16 08:12:10
{"Type":117,"F":[1,1.23714005947,1,1.23715996742,1,1523880729]} | 2018-04-16 08:12:10
{"Type":3,"F":[0,1523880740]} | 2018-04-16 08:12:21 (Heartbeat)
Date Time Of Last Edit: 2018-04-16 12:13:38
