Date/Time: Sun, 19 Jan 2025 15:20:21 +0000
Charts Disappeared
View Count: 746
[2018-04-15 22:20:10] |
User411633 - Posts: 4 |
Hi, All or most of my charts have disappeared on what looks like all of my chartbooks. Not sure why? Help! |
Private File |
[2018-04-15 22:33:49] |
See if the charts are listed under the CW menu. Refer to the instructions here use a backup Chartbook: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-17 02:51:39] |
This issue is related to 1731 and is explained here: Version 1731 Only Opens One Chart from Chartbook Using a backup Chartbook would not help. You need to update to 1732. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
