Date/Time: Sun, 19 Jan 2025 15:13:13 +0000
Two installations of SC
View Count: 774
[2018-04-15 21:28:06] |
User342238 - Posts: 44 |
Hi, I have two installations of Sierra Chart running under two different sierra chart accounts, one that I pay directly to SC for use with bitmex, and the second is free via AMP futures. I installed the 64 bit version of SC firstly and it was running fine with bitmex. Then I installed second copy of sc to use with amp. Now I am no longer able to run the 64 bit version with bitmex, it automatically defaults to 32 bit version. With the amp setup I have the option for both. As you can see in the image of my windows 8.1 desktop there are three sierra chart options, the first in the list opens bitmex with 32 version, the second opens amp in 32, and the third opens amp in 64. The SierraChart_64 icon previously opened bitmex in 64, now it links to the amp account.
[2018-04-16 13:26:23] |
You need to go to the installation folder for the Sierra Chart you are using with BitMEX and then set up a shortcut on your desktop to the SierraChart_64.exe file. Be sure to give it a name that identifies that it is for BitMEX or whatever you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
