Date/Time: Sun, 19 Jan 2025 15:10:48 +0000
Moving Average Direction
View Count: 988
[2018-04-15 14:39:01] |
User424077 - Posts: 38 |
Hello, Is it possible to get direction from the Moving Average. I'd like to get direction arrow to where the Moving Average is heading with average of x periods back. For example 5 periods Up/Down Or Flat to have arrow on the screen instead of full indicator. Please advise. |
[2018-04-16 13:13:40] |
Use the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition If you look at the example formula section you will see ones that show how to determine the slope (up or down): Study/Chart Alerts And Scanning: Alert Formula Examples Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-16 13:13:52
