Date/Time: Sun, 19 Jan 2025 12:40:27 +0000
Option for
View Count: 804
[2018-04-14 14:01:28] |
User45989 - Posts: 54 |
Hello, When configuring a control bar button, the command for "Export Bar and Study Data to Text File" appears to be missing from the "Available Control Bar Commands" in the "Customize Control Bar" menu. thank you, |
[2018-04-14 22:57:26] |
We will add this.
