Date/Time: Sun, 24 Nov 2024 05:32:56 +0000
Open E cry OCO
View Count: 1843
[2013-10-07 08:51:49] |
NumbersBars - Posts: 141 |
Hi, I'm not sure if this question is repeated, as I can't find any answer after browsing the support board. My understanding is that, Open E cry supports server-side OCO. However, when I submitted a simple bracket orders, only parent order is sent to Open E cry, while the rest are being held on my PC until parent order is filled. Is there any configuration I need to change in order to have both Child and Parent orders sent to Open E cry, so that the orders are held at sever (before parent order is filled)? |
[2013-10-07 13:43:08] |
Any comment from SC support? Or child orders are always held on user's PC (for those trading with Open E cry)? |
[2013-10-07 18:04:04] |
This is not supported. This is explained here: https://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html The child orders are held on the client-side until the parent order fills. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
