Date/Time: Sun, 19 Jan 2025 12:26:16 +0000
I can't log onto FXCM server
View Count: 799
[2018-04-13 16:11:53] |
User763667 - Posts: 1 |
Hi When I enter FXCM standard live accounts, I see no server. What is the issue. Kind Regards Rick Date Time Of Last Edit: 2018-04-13 17:53:04
[2018-04-13 17:52:51] |
You need to follow through the step-by-step instructions here: https://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#Setup Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
