Date/Time: Sun, 19 Jan 2025 12:42:56 +0000
Journaling - possible to create 'note' pop-up?
View Count: 1373
[2018-04-13 09:32:47] |
User7817001 - Posts: 96 |
Is there a function which allows one to journal entry after a trade entry, and also trade exit, is placed. I am thinking of a checkbox option (General Settings?) which would open a popup field, where one could enter text, and it would save both sets of text entries into the trade activities (see attached). Yes, I am aware of the spreadsheet availability, it is too cumbersome for this, imo. Thank you, Mark |
Capture.JPG / V - Attached On 2018-04-13 09:32:30 UTC - Size: 147.75 KB - 419 views |
[2018-04-13 18:20:48] |
There is something close to this and it is documented here: Basic Trading and the Trade Window: Set >> Text Tag But it looks like you are already aware of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-14 10:25:04] |
Thank you for the recommendation. Although it DOES allow for custom text in individual trades records (rows), it is not originally setup for trade journalling. It is not flexible, one cannot simply enter custom text before and after each individual trade. Thank you, Mark |
