Date/Time: Sun, 19 Jan 2025 12:37:26 +0000
Bid&Ask Volume by price of a bar
View Count: 719
[2018-04-13 08:32:39]
User523468 - Posts: 27
Using a standard candlestick chart on a one second time frame, I want a marker to be drawn next to a price level with the most volume(bid side/ask side) compared to the entire bar.
Is there a study capable of carrying out this task?
[2018-04-13 18:10:47]
Not exactly this. But you can use to Numbers Bars study and configure it to color price levels as you require:
Numbers Bars
Have a look at this coloring method:
Numbers Bars: Text Coloring Based on AskVol/BidVol Percentage
When setting the percentage thresholds, you will want to set the last threshold to 1.0.
Date Time Of Last Edit: 2018-04-13 18:12:32
