Date/Time: Sun, 24 Nov 2024 06:12:46 +0000
Security
View Count: 1445
[2013-10-06 23:32:07] |
TastyRisk - Posts: 119 |
Why doesn't SC app have a digital signature ? |
[2013-10-07 10:05:50] |
For what purpose? It also only complicates the release of the software which we do not want to do. When you download Sierra Chart from the Sierra Chart website, you know you are getting a known good copy of it. So what's the point of some signature? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-07 10:06:41
[2013-10-07 12:00:08] |
In case I want to deploy it on a remote server and need to maintain a secure environment. |
