Date/Time: Sun, 19 Jan 2025 12:32:14 +0000
Unfinished Business in NBs
View Count: 1325
[2018-04-13 06:11:22] |
nicktrader - Posts: 730 |
In NBs I am using the Coloring Method "Based in Diagonal Dominant". In case of an unfinished business (nonzero H/L) it makes no sense (from my point of view) to highlight it. Perhaps it is possible to avoid this. |
unfished business.png / V - Attached On 2018-04-13 06:09:59 UTC - Size: 39.77 KB - 490 views |
[2018-04-13 16:15:00] |
John - SC Support - Posts: 37327 |
Check to see if the option for Enable Diagonal Zero Bid/Ask Compares is set to Yes. This setting allows those values at the High and Low to treat the non-existent data as zeros. You can find the documentation for this here: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_EnableDiagonalZeroBidAskCompares If this is not the case, then let us know the full name of the Background Coloring Method you are using. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-13 16:39:32] |
Okay, now it works. I changed the option in "No".
Date Time Of Last Edit: 2018-04-13 16:39:49
Enable Diagonal Option.png / V - Attached On 2018-04-13 16:39:06 UTC - Size: 16.03 KB - 425 views |
