Date/Time: Sun, 19 Jan 2025 12:37:15 +0000
New account questions
View Count: 1102
[2018-04-12 22:54:41] |
User123003 - Posts: 29 |
Hi, I just made payment so I have following questions: 1. What's different between standard vs. advance package? Because I need to purchase SC, so I need to know what is the difference and the price also different between these two 2. How to set multiple symbols in one chart? 3. I want to trade Forex, so what is symbol and how to set up to trade? With TDAmeritrade or any other brokers. 4. How to set up for TDAmeritrade? How to get to second chart? It seems to me it only can do minute chart. 5. What's CTS? 6. How does additional system works? and 2 systems are included. Does this mean that I can use the same account to use SC at 2 computers at same time? Thank you, Frank |
[2018-04-13 01:06:47] |
OK thank you for the payment. 1. The differences are explained here: Description of Service Packages and Pricing: Packages In general, the difference is going to be that the Numbers Bars and TPO Profile Chart studies are included with the Advanced service package. 2. The best way to do this is through the Add Additional Symbol study. This is explained here: Working With Charts: Overlaying Multiple Symbols in a Single Chart Window 3. Forex trading is not supported through TD Ameritrade. Did you want to trade Forex futures instead? 4. Here are the set up instructions for TD Ameritrade: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php But really TD Ameritrade cannot be used for futures or Forex trading. The only reasonable choice for cash Forex trading for a US customer is going to be Interactive Brokers: Interactive Brokers Trading Service Otherwise, you can trade Forex futures through any supported futures trading service. Let us know if that is what you want to do. Would be better. Charts based on seconds are fully supported. Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar 5. CTS is a trading platform service which is fully documented here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php You can use CTS. Many brokers support that. 6. Yes this is correct and is explained in detail here: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-13 01:08:38
