Date/Time: Sun, 19 Jan 2025 12:37:42 +0000
CPU usage
View Count: 757
[2018-04-12 20:34:55]
User161790 - Posts: 2
Hi, this week my replays have become so slow it is virtually impossible to run them. Often they also get stuck. Today I noticed SC was using a lot of CPU power > between 20 - 35%. This seems way too high for this app.
Do you have any idea what might be going on and if this is connected to my slow replays?
Thank you
[2018-04-13 00:55:26]
This might be because of the Replay Mode. Refer to help topic 30.41 here about this:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.41 - Slow Replay Due To Back Test Modes
Otherwise, refer to the other items on that page for other causes.
[2018-04-13 02:02:41]
I am sorry, but this is not very helpful. I looked at 30.40, 30.41 and 30.37, but it doesn't help me find the cause because none of these seem to be happening in my case.
Also, I am in Win10 and the image you show in section 30.37 is from Win 7 I think.
I have none of the events described in these sections happening.
I run a pretty fast pc with I7, 32GB and 1TB SSD. Only 2 charts, 1 symbol. The pc I use is dedicated for trading, no surfing, no additional programs installed.
I can open any dialog window, causes no problem.
My replay mode has to be 'Accurate trading system back test mode' since I am testing for auto trade system. Last week my replays flew through at speed 100000, after the weekend suddenly super slow, like 2 min at the time.
Any other suggestions?
[2018-04-13 03:26:30]
It does not matter the particular operating system version you are running.
You really have to go through this with a process of isolation. Remove all studies from the chart and just replay one chart and see if there is an improvement.
