Date/Time: Sun, 19 Jan 2025 12:35:18 +0000
remove/modify large volume bar
View Count: 783
[2018-04-12 20:26:30]
User845611 - Posts: 13
Is there a way to delete or modify an extra tall volume bar(# trades) that makes all the other bars flat line? Either I don't get the scale features or they will not prevent the flat line. Thanks for any enlightenment here.
[2018-04-13 01:09:41]
Yes. You can edit the data. You can do this through the Edit menu:
Working With Charts: Overlaying Multiple Symbols in a Single Chart Window
Is this an Intraday or Historical chart?
