Date/Time: Sun, 19 Jan 2025 12:33:22 +0000
[User Discussion] - Sharing Drawings
View Count: 892
[2018-04-12 20:13:59] |
User228927 - Posts: 55 |
I know you can share drawings from main chart to main chart, thru chart settings (Advanced Studies 2). Is there a way of sharing a drawing made on one subgraph of a chart to another subgraph of a different chart.
[2018-04-12 20:16:32] |
No.
