Date/Time: Fri, 24 Jan 2025 14:54:45 +0000
LMAX Question
View Count: 1259
[2018-04-12 16:23:02]
User518169 - Posts: 9
Is there a way to view balance and equity from sierra?
open positions on the chart show 0.00C and in “trade orders and posions” the balance tab is blank.
[2018-04-12 19:01:56]
Account balance data is not available from LMAX.
In regards to Trade Positions, refer to:
LMAX Trading Service: How Current Trade Positions Are Determined
[2019-01-21 16:53:18]
ILIM KIRGIZ - Posts: 187
Hi engineering,
I'm also LMAX user and I need to be able to know my account balance for correct position sizing calculations.
If I can grab account balance data by using my own methods, how can I push this data to Sierra Chart?
Thanks.
[2019-01-21 18:43:48]
You could write it to a text file and read it from the text file using ACSIL:
Advanced Custom Study Interface and Language (ACSIL)
This provides a very simple means of interprocess communications.
[2019-01-22 18:13:35]
I obtained the data via API from LMAX. In this way, I can get the LMAX balance to my custom developed position sizing study. This is okay.
Is it also possible to update internal Sierra balance value which can be seen through Trade, Orders and positions, balance menu? If yes how?
Thanks.
[2019-01-22 18:28:42]
No, there is not a way to do this unless you provide a full trading server using the DTC protocol.
[2019-01-22 20:29:43]
Thanks for the answer.
As I trade on LMAX I enabled Trade >> Use Fill Calculated Positions - Global setting.
Afterward, I assume that Sierra might calculate profit and loss statistics internally. Can it also calculate account balance according to this data? If yes, how I can set initial account balance for the live account manually?
[2019-01-24 16:00:33]
Dear support my I have a reply to the above question of mine?
Thanks.
[2019-01-24 20:59:40]
While Sierra Chart does now have this kind of functionality in its core, for calculating the account balance. It is not something that is really set up to be used quite like this or at least it would have to be tested. It is not something we can allocate time to now.
[2019-01-27 15:59:50]
tradingest - Posts: 4
Hi guys,
Anybody can you help me to set LMAX account with Sierra?
[2019-01-28 00:26:46]
Follow the instructions here:
LMAX Trading Service: Setup Instructions
