Date/Time: Sun, 19 Jan 2025 12:22:39 +0000
DTC Trading
View Count: 859
[2018-04-12 13:40:30] |
Trade Nice - Posts: 75 |
If using the DTC-Server and DTC-Sub instance [trading] (Interactive Brokers) For chart trading from a DTC-Sub instance... should 'Global Settings >> SC Server Settings > Allow Trading' be enabled on the 'Server' and/or 'Sub Instance'? |
[2018-04-12 16:22:31] |
Always on the server instance.
