Date/Time: Sun, 19 Jan 2025 12:38:07 +0000
sc.GetOrderByIndex question
View Count: 828
[2018-04-11 21:29:01] |
@sstfrederik - Posts: 405 |
is sc.GetOrderByIndex processing orders based on InternalOrderId number? Start at lowest to highest?
[2018-04-12 00:05:19] |
There is no particular order in which the orders are organized and they can change.
