Date/Time: Sun, 19 Jan 2025 12:43:11 +0000
Order Cancelled Voice
View Count: 856
[2018-04-11 20:42:51] |
User509438 - Posts: 7 |
Hello. each time I cancel an order, I get a voice alert that says "order cancelled." Where is that setting managed? Can I - remove that voice OR - add more voices to different conditions, such as order entered, or order filled, etc. thanks |
[2018-04-11 20:53:48] |
This is controlled through the Alert Sound Settings: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#Tab_General3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
