Date/Time: Sun, 19 Jan 2025 12:22:10 +0000
es s&p mini
View Count: 552
[2018-04-11 20:14:41] |
User165188 - Posts: 1 |
the es has a value of $50 per point X # of contracts why does that not work on the p/l calculations? why does the system not work that way? Thanks
[2018-04-12 19:00:29] |
This can be changed. Refer to this setting here: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) And refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
