Date/Time: Sun, 24 Nov 2024 05:30:05 +0000
[User Discussion] - time highlights settings
View Count: 1812
[2013-10-06 17:58:31] |
AKR - Posts: 523 |
can anyone tell me if the shades on the chart below are made with the "time range highlight" study? is there a possibility to automatically change the highlight periods depending on the bar period? eg: if I have 1min chart I would like to have hours highlighted. if I have a 60min chart I would like days highlighted. switching the chart to a dayly I might want to highlight weeks or monts. Is that possible? http://www.sierrachart.com/image.php?l=1379632329689.png |
[2013-10-06 20:43:26] |
M5amhan - Posts: 468 |
it looks like they have it set to highlight extended hours.. time range highlight is set based on a set time (ex: 08:30:00 - 15:14:59) so no it wont automatically change based on your time frame
[2013-10-07 13:31:17] |
AKR - Posts: 523 |
thx! and do you also know a way how to automatically set time lines? in which way ever, can also be simple lines. |
[2013-10-07 14:56:59] |
what do you mean automatically set them?
[2013-10-07 16:14:11] |
AKR - Posts: 523 |
See first post ...
[2013-10-07 16:20:24] |
ok see second post
[2013-10-07 16:24:45] |
AKR - Posts: 523 |
well, second post tells me, that time range highlight is based on a fixed time and so wont change automatically on change of bar period. so my question is, is there a possiblity, that when eg I look at an hourly chart I have vertical lines separating each day. and when I change the same chart to a daily one, the vertical lines should automatically change to eg weekly lines. and probably when changing same chart to minute one then make hourly vertical lines. thx! |
[2013-10-07 16:30:08] |
from what i know about how SC codes the platform, most of the features are static and not dynamic like you are talking about. and i dont know of any studies that would do this either. the closest thing i could think of would be to use vertical grid lines and set the settings to pixels through chart settings > advanced settings 2 .. that wont be placed in certain areas like every hour/day though
[2013-10-07 16:31:15] |
AKR - Posts: 523 |
ok, anyway thank you!
