Date/Time: Sun, 19 Jan 2025 12:36:45 +0000
automatically generating text
View Count: 755
[2018-04-11 17:54:03] |
User530089 - Posts: 4 |
On a chart with the numbers bar study, after each bar completes, I am putting custom text either below or above the bar based on my interpretation of the bar. Is there a way to automatically generate this through some code? If so, can you point me in the direction to figure it out? Thanks |
[2018-04-11 18:20:17] |
Yes. Refer to: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
