Date/Time: Sun, 19 Jan 2025 12:20:40 +0000
adding market data
View Count: 720
[2018-04-11 16:13:44] |
User531665 - Posts: 4 |
Hello, I added 1 user and added a few market data including stocks (NYSE/NASDAQ/BATS) and CBOE. Is there a data feed I need to add to include the VIX Futures? I don't see them under CBOE Index. I believe the symbol may be VX. These would be the monthly VX futures not the index. I just need to know what exchange data to add and possibly the symbol that Sierra uses. If you can please let me know so I can add that. I looked through the entire Sierra website and did not find before submitting this ticket. Thank you, Ronnie |
[2018-04-11 18:18:42] |
You will need to activate this exchange: CFE Futures 21.00 USD/month The symbol depends upon what Global Settings >> Data/Trade Service Settings >> Service is set to. Let us know. We might need to add the symbol for the particular service you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-11 18:19:05
