Date/Time: Wed, 22 Jan 2025 12:50:06 +0000
tick size
View Count: 2187
[2018-04-11 15:19:34]
User123235 - Posts: 46
Hi, is there a tick size for the control bar?
[2018-04-11 16:46:15]
User701453 - Posts: 176
Your question is lacking a lot of detail about what you want..
However if you are looking to create a custom button on the control bar to change the tick size of your chart.
If so, then this documentation page shows you how to do that.
Control Bar
You can create a new button and you can set it to time based, renko bar as well as ticks.
I have a button that allows me to switch from Renko chart to 1000 Tick chart by clicking the button.
[2018-04-11 20:26:26]
For example, ES tick is .25 and I want a control button for .50 tick size. Thanks in advance.
[2018-04-11 20:38:10]
Not sure why you would need the tick size of the symbol in a button?
But either way, that's something I cant assist with...
[2018-04-11 21:09:22]
The tick size for a chart can only be changed with this particular setting:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
[2018-04-11 22:05:20]
Thanks, any plans in the future to turn it into a button?
[2018-04-12 00:05:57]
No, definitively not.
Date Time Of Last Edit: 2018-04-12 00:06:04
[2018-04-12 00:06:59]
Xfanman1 - Posts: 320
With a duplicate chart set to .50 tick you’d still be one Chart Tab click away from your .50 Tick Chart? Same effort as a button.
Scott
[2018-09-28 17:06:59]
So how can I go about creating .50 tick button? Total newbie here...
[2018-09-28 18:22:40]
You cannot without custom ACSIL programming. You just need a separate chart and that is what the user above is saying.
