Date/Time: Sun, 19 Jan 2025 12:39:03 +0000
SendOrdersToTradeService is not consistent with 'Trade
View Count: 1385
[2018-04-11 14:35:24] |
User366976 - Posts: 3 |
Hello, I have study for automated trading and today the study wanted to entry the market with following result: ZBM8 #1 | SendOrdersToTradeService is not consistent with 'Trade >> Trade Simulation Mode On' setting. Order action ignored. | 2018-04-11 05:55:037 The setting I had following in TRADE menu: Trade Simulation Mode On = without check mark Auto Trading Enabled - Global = check mark is present Auto Trading Enabled - Chart = check mark is present In the study I have this part of code: SCInputRef OrdersToServer = sc.Input[1]; OrdersToServer.Name = "OrdersToServer (No=SIM, Yes=Live):"; OrdersToServer.SetYesNo(0); sc.SendOrdersToTradeService = OrdersToServer.GetYesNo(); And in the study input it was switched to YES. Can you help and explain? Thank you |
[2018-04-11 19:18:40] |
Refer to: Automated Trading Management: SendOrdersToTradeService Make sure this line: sc.SendOrdersToTradeService = OrdersToServer.GetYesNo(); Is below the sc.SetDefaults code block. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-11 19:18:46
