Date/Time: Sun, 19 Jan 2025 12:29:00 +0000
[User Discussion] - Cant update Sierra
View Count: 931
[2018-04-11 10:25:47] |
grantx - Posts: 244 |
Help -- download current version Help -- download pre release Neither one is working. I try to initiate the update and Sierra shuts down as normal but then nothing happens. I can restart it and go back in but when I try to update again the log tells me: Failed to open the file: C:\SierraChart\SierraChartFileDownloader.exe. Error: Windows error code 32: The process cannot access the file because it is being used by another process. I've restarted the computer but that doesnt help. |
[2018-04-11 11:01:30] |
Xfanman1 - Posts: 320 |
Try this --> Unable to Update Sierra Chart -- Scott |
[2018-04-11 17:59:03] |
Refer to this post about this issue: Unable to Update Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
