Date/Time: Sun, 19 Jan 2025 12:42:00 +0000
Weekly or Monthly Percentage change on Quoteboard possible?
View Count: 839
[2018-04-11 09:59:26]
User164231 - Posts: 278
Beside daily percentage change, is there a way to add weekly and monthly percentage change on quoteboard?
If it is not possible, what are the ways of doing it without cluttering another region with oscillator? It would be nice to hover over the weekly or montly candle bar and have the value pop out.
Thanks.
[2018-04-11 18:12:51]
No, this is definitely not supported.
You need to use a Weekly and Monthly chart for this.
