Date/Time: Sun, 19 Jan 2025 12:32:12 +0000
Spreads through CQG
View Count: 1056
[2018-04-10 18:20:39]
Usermb - Posts: 126
Using SC 1727, I cannot trade spreads using my CQG account.
Example:
CQG Symbol: "CHGI0Z8"
If I open this symbol in a SC DOM (Symbol: CHGI0Z8) I do not get any quotes in the DOM.
If instead I open "F.US.CHGI0Z8", I get quotes but I cannot trade it: "CQG order update (Rejected). Text: Symbol is incorrect or not defined. Internal Order ID: *******. Service Order ID: (none). Symbol: F.US.CHGI0Z8 | 2018-04-10 19:52:42 *"
This is because CQG expects "CHGI0Z8".
I can trade this symbol using CQG Mobile, this problem seems to be specific to SC.
This symbol is just an example, this problem affects all Spreads.
[2018-04-12 19:51:11]
This symbol format is correct: F.US.CHGI0Z8
Although you might want to change the year to 18 but make sure you do not use the single digit year symbol anywhere else in the Chartbook and reconnect to the data feed after.
Refer to:
CQG Trading Platform Service: CQG Exchange Traded Strategies/Spreads Symbol Format
This message is from CQG:
Date Time Of Last Edit: 2018-04-12 19:51:28
[2018-04-12 20:30:01]
Usermb - Posts: 126
Switching to two digit years fixed the problem with placing orders.
