Date/Time: Sun, 19 Jan 2025 12:43:41 +0000
Overlapped Numbers
View Count: 858
[2018-04-10 16:19:25] |
User583898 - Posts: 7 |
Thank you for the advice. Everything works fine so far. The only thing is, that the numbers are overlapped only in the chart dom. CanĀ“t sort it out by myself: https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=18409 |
[2018-04-10 18:22:46] |
You will have to use Interactive Scale Range to reduce the range of displayed prices. Refer to: Chart Scale and Scale Adjusting: Interactive Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
