Date/Time: Sun, 19 Jan 2025 12:30:05 +0000
Different Attached orders conditions for Long and Short
View Count: 847
[2018-04-10 15:17:12] |
User513228 - Posts: 41 |
Hi, it´s possible using different condition for Long and Short positions ? For exampe 1% stoploss for long and 2% stopploss for short
[2018-04-10 18:10:54] |
No, this is not supported. Other than to create separate Trade Window configurations: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-10 18:21:09
[2018-04-10 18:21:15] |
The prior post has been updated.
