Date/Time: Sun, 19 Jan 2025 12:17:39 +0000
Trade DOM Market Depth Volume Profile
View Count: 1938
[2018-04-10 14:47:30]
User740496 - Posts: 32
In 1730 the volume profile bars for Market Depth on Trade DOM has disappeared? I can't find the previous tick box to show volume profile bars and charts now fully shade all the market deoth boxes?
[2018-04-10 18:11:28]
Refer to:
Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns)
[2018-04-10 18:16:38]
This is set through Trade >> Customize Chart/Trade DOM Columns, with the Show Volume Bars setting. Link to description is above.
Date Time Of Last Edit: 2018-04-10 18:22:03
[2018-04-11 07:27:03]
Completed this change in 1730, but no change. Attached screenshot shows highlighted market depth but not volume profile (max volume bar width set to 70). Thanks.
image11Apr18.PNG / V - Attached On 2018-04-11 07:25:26 UTC - Size: 72.78 KB - 443 views
[2018-04-11 18:11:20]
Make sure you open the Customize Chart/Trade DOM Columns window from the particular Trading DOM Trade menu you want to set it for.
[2018-04-12 07:22:08]
Not working. I have also rolled back to 1727 as not happy about the arbitrary removal of formatting from Time & Sales in 1731 and my wasted time then looking for the normal menu / format control items - which have now been moved to completely new location. This is not good.
[2018-04-12 07:39:25]
OK so I now have volume bars in 1727, but bars do not move with text. So if I right align the Bid volume depth, volume bars stay on left. Is this fixed? Thanks
[2018-04-12 19:38:43]
There is nothing arbitrary about this but the setting of the new time and sales color settings from the existing colors was not yet implemented. This was still a prerelease.
And we see no problem with the volume/quantity bars for the Chart/Trade DOM market data columns in 1731. They work properly.
We will check if anything has changed in this regard.
Date Time Of Last Edit: 2018-04-12 19:39:04
