Date/Time: Sun, 19 Jan 2025 12:28:17 +0000
Custom Study
View Count: 907
[2018-04-10 08:38:35] |
User360283 - Posts: 506 |
I have been using custom study "To The Tick" for years. I recently updated using the alternate updater as per your instructions. "To The Tick" dll is now gone. It is not available via the "Add Custom Study" How do I get it back? Help please thanks |
[2018-04-10 09:34:25] |
Exit from Sierra Chart and run Sierra Chart again using the icon on your desktop without _64 at the end.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-10 09:34:39
[2018-04-11 17:25:00] |
JoseyWales - Posts: 67 |
If you want to use 64 bit Sierra Chart, try using the "To the Tick" study found in UserContributedStudies_64.dll. Maybe it is the same study that you had a separate dll for. |
