Date/Time: Sun, 24 Nov 2024 05:56:59 +0000
referencing another spreasheet
View Count: 1299
[2013-10-06 04:10:03] |
toews&kane - Posts: 209 |
Hi, In spreadsheet trading is this still doable? There's a set of macro data lets say I want to get from a daily chart and another set of data I want to get from a 30 min chart. The main trading chart will be the 30 min chart. If it's doable how would I do this? |
[2013-10-06 08:56:31] |
Yes. See: http://www.sierrachart.com/index.php?l=doc/doc_ReferencingChartsFormulas.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-06 19:49:02] |
I imported the daily time frame spreadsheet into the 30 min one. but the times are not synching up. i.e I have on the daily chart value A at 8:30am 10/4/2013, but when imported in to the 30 spreadsheet as a study value A shows up at 10/4/2013 5:00am |
