Date/Time: Sun, 19 Jan 2025 12:26:24 +0000
Running SC on Multiple Monitors
View Count: 3537
[2018-04-10 03:30:43] |
Quantico - Posts: 45 |
Is there any was to split charts to multiple monitors?
[2018-04-10 04:58:29] |
Yes. Refer to: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
