Date/Time: Thu, 28 Nov 2024 08:48:12 +0000
Re-center all Chart DOM short cut key
View Count: 4179
[2018-04-10 02:52:51]
YK - Posts: 33
Hello SC Team.
I use mainly Chart DOM with Numbers Bars study.
1. How can I re-center the all Chart DOM in the Chartbook?
I'd like to re-center all the Chart DOM on one shortcut key like Trade DOM. If you don't have the ability this feature, please consider add this feature.
2. Please also consider add this feature.
General Settings > General 2 tab.
"Scroll Wheel Scrolls Chart Vertical. With 'Shift' Scrolls Chart."
Thank you.
[2018-04-10 18:31:37]
Here is the command for that:
Trade Menu: Re-Center Trade DOM Scales (Trade menu)
Additionally:
The Chart DOM can be recentered simply by double clicking on the Price scale. This is the same functionality that exists regardless of whether the Chart DOM is displayed or not.
You can find the documentation on this here:
Chart Scale and Scale Adjusting: Resetting the Scale
The following documentation is related specifically to the Chart DOM scaling:
Chart Trading and the Chart DOM: Scaling the Chart DOM
Additionally, you can create either a Control Bar Button, or a Keyboard Shortcut to reset the Chart DOM Scales by using the Reset Scales item. You can find documentation for how to create these here:
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
and here:
Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings)
[2018-04-11 02:32:31]
YK - Posts: 33
OK. I need "Reset Scales All Charts" command. Thank you.
[2019-02-23 23:26:46]
whats1thingnow - Posts: 407
+1
[2019-05-07 11:49:32]
User745789 - Posts: 321
+1 again. Vertical scrolling with the mouse wheel always works well with the Trade DOM, even if scroll wheel support is globally disabled. Nice to have same when trading from a chart DOM.
[2019-05-08 16:55:32]
We will see about adding this capability to a Chart DOM for a chart.
[2019-05-08 16:56:23]
Also this is still on our to do list:
[2019-05-09 15:06:34]
There will be two new scroll wheel options to support scrolling of the vertical scale on a chart , in the next version.
[2023-05-12 18:51:15]
User370774 - Posts: 25
Did this ever get implemented?
To clarify the difference between the requested "reset/recenter all DOMs" and double clicking on the price or scroll wheel functions...
Assume you have multiple DOMS open and you want them to center all to the same or current price.
You gotta be clicking and scrolling reeeeeeal fast to get close to that in fast price action :)
