Date/Time: Sun, 19 Jan 2025 12:22:03 +0000
[Programming Help] - Processor
View Count: 776
[2018-04-09 19:14:12] |
User731023 - Posts: 138 |
Hello, When you hide a study, like an Oscillator as example, does it still use some of your computers processing power? I am asking because there may be something I want to use in a chart at some point, would rather not to have to reload and configure it. I would, if it did use up (slow down) any processing power. Thank you |
[2018-04-13 06:45:47] |
Rino - Posts: 124 |
A yes or no would be sufficient. Thanks |
[2018-04-13 17:55:29] |
It is still calculating but the processor time is essentially nothing. It would not even be measurable or impacting.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-13 17:55:42
