Date/Time: Sun, 19 Jan 2025 12:29:54 +0000
Managing partial fills in ACSIL
View Count: 1160
[2018-04-09 18:50:58]
@sstfrederik - Posts: 405
A quick question on partial fills since it is a bit hard to simulate.
Can a partial filled LMT order be cancelled using the InternalOrderID and will the quantities of any attached orders be adjusted as well?
edit:
What is the order status of a partial filled order?
Thanks.
Date Time Of Last Edit: 2018-04-09 19:04:02
[2018-04-09 19:10:55]
You can cancel a partially filled order. That is not a problem.
For an understanding of quantity management for Attached Orders, that is thoroughly documented here:
Attached Orders
The status of a partial filled order will be Open:
Trading Information Windows: Order Window Field Descriptions
