Date/Time: Sun, 19 Jan 2025 12:18:07 +0000
Using Sierra Forex data with LMAX
View Count: 734
[2018-04-09 16:10:21] |
Giamsterdam - Posts: 33 |
Thank you for all the previous help, but I have some more questions. Would it be possible to use the Sierra Forex data together with LMAX for my execution. I have been doing some comparisons with your nd LMAX and I am not really impressed with LMAX data eventhough they claim to offer level 5 data. Would it be possible to use SC data and still execute LMAX and if so how?? Cheers, Giacomo |
[2018-04-09 18:35:44] |
This is not supported.
