Date/Time: Sun, 19 Jan 2025 12:25:15 +0000
Instance 1 and DOM
View Count: 1144
[2018-04-09 16:06:27]
nicktrader - Posts: 730
The DOM of the Instance 1 show me a candle on the left hands side since vers. 1730. The other problem is still the known problem of the vanished "Ask Size Volume Bars" (from time to time.
I am using CQG.
imageInstance 1 - DOM.png / V - Attached On 2018-04-09 15:58:59 UTC - Size: 67.13 KB - 359 views
[2018-04-09 18:46:16]
You must have a study on the Trading DOM which is drawing that chart bar. Remove the studies one by one and see which one is doing that.
This is something CQG specific and we are not able to reproduce and do not know why it happens. It is not something we can spend time on now.
Date Time Of Last Edit: 2018-04-09 18:46:32
[2018-04-09 19:47:54]
Can you confirm that this occurs on a sub instance of Sierra Chart and not the main instance. Our understanding is that this occurs on a sub instance.
And if you reconnect to the data feed does that resolve it?:
Date Time Of Last Edit: 2018-04-09 19:48:14
[2018-04-10 06:58:19]
- Problem was caused by a study - I fixed it
- it occurs only on a sub instance
imageDOM Instance 1.png / V - Attached On 2018-04-10 06:57:41 UTC - Size: 118.79 KB - 308 views
[2018-04-10 17:51:05]
OK we will keep looking into the market depth data issue with CQG in a sub instance.
