Date/Time: Sun, 24 Nov 2024 05:42:50 +0000
Question
View Count: 1320
[2013-10-05 18:32:45] |
p20720 - Posts: 3 |
Hi SC Support, The SC software used to come with a Watcom compiler but it's no longer the case. 1) Is there any default compiler within SC now or does one has to always go to Analysis>>Build Advanced Custom Studies DLL>>Install Compiler and download the compiler using this route? 2) Does the compiler downloaded through the above "Install Compiler" route compile all the .cpp files within the SC's ACS_Source folder and most/all of the outside custom .cpp files? Thanks. |
[2013-10-05 20:27:39] |
1. You do need to use the Install Compiler button to get it. 2. The compiler will compile any CPP file. CPP files could contain errors or they can may be missing the SCDLLName ("") line at the top which will prevent the build from completing successfully though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
