Date/Time: Sun, 19 Jan 2025 12:34:47 +0000
Reversing Fib retracements
View Count: 771
[2018-04-09 14:15:44] |
User742511 - Posts: 4 |
Is their a way to reverse Fib retracement with one click. I see swap anchors but it does not reverse the fib value?
[2018-04-09 18:50:34] |
No, there is no way to change the direction of the Retracement with only 1 click. The only option is to use the Adjust Drawing option, and move one of the anchor points.
